TFI GEN3 fastcard install.
19K views 151 replies 40 participants last post by  rtpassini
well i got my fast card gen 3 from CYCLECONNECTION for my race baffle 07 R1 and first off let me say WOW. the install takes minutes, it took more time taking the seat off and proping up the tank then puting the fast card in. well after the install i took her for a ride and i dont know if its me but the exhaust has a different note (sounds really nice) and there is a noticable difference in power and response. this thing pulls like a beast!!!
Yes,
It does change Exhaust tone, it did it to mine. I told you it was the real deal. I'm glad your happy with the FASTCARD GEN III.
Stan
Another happy customer, it's starting to spread the word is getting out the FAST CARD IS THE TRUTH what you will soon realize is how much faster your getting to your peak HP, I'm curious to see how mucm HP/TQ you are making on your local dyno I whatched stan1 get tuned and he put down 171.5 HP on a land and air dyno which reads low, if your local tuner uses a dynojet it will read much higher. All I can say is enjoy it because I'm enjoying mine.:drunk:
What's up Matt?
Are you going to make our WV trip?
Stan
#11 ·
#19 ·
Go to Powercommander.com.... How much is the PCIII? It's $339.95.
Stan
You'll find out. I bet you, that you'll love it..... Also it only $175 do get it mapped, and $269 fpr the FASTCARD.
Stan
#29 ·
i think the fast card is a great new option, if you like the powercommander then great, but if you want to try something new then go for it. i got screwed on my wideband from dynojet and the techs said myself and a few other members here who had it were wrong and not the product...... the wideband was a piece!!!! shaun from cycle connection called me to check if my package had arrived, called me to give me install directions and tips and then called again to see how i liked the results and to give me some fine tunning pointers. that is service!!!!!!!! so if your open to a new product from a great guy willing to help in anyway, why not try it out?
#31 ·
Are you going to do Race Baffle's?
Stan
#35 ·
Just give Shwan a call at 301 874-1168.
Stan
ok this sounds good so no mapping to be done just plug in and go?.. i want to do the race baffle the y pipe and a filter
Thanks
#36 ·
i still want to know how the fast card works and what adjustments you can make with it.
im not doubting it, as obviously a few of you are very happpy with it, but so far on the 3 or 4 posts that have started about this there is nothing about how it works. im not talking about marketing speak im talking about how it works. also is it able to make the secondary throtle blades open further below the preset rpm's on the 07 and if so how.
#40 ·
Just give Shwan a call at 301 874-1168. He'll can tell you all about it...
Stan
#41 ·
Dobeck TFI, is the GEN II version they sell.... The GEN III can only be bought from tuner's. FASTCARD GEN III is more advance than the TFI GEN II. They are both made by Dobeck. When I go back to get my AKro EVO 2 map... I'll make sure to post some video.
Also if you have more questions just give Shwan a call at 301 874-1168.
Stan
#42 ·
isnt shawn who has posted on here, including recently in the for sale section where you are selling your pc??
why cant anyone post up how it works and what you can adjust???
and one dyno comparison where with the pc it was tuned too rich and the fast card made more hp imo because it was tuned to be a little leaner then the pc doesnt really say much. The claim to fame as far as i can tell is its load based. An inertia dyno is not good a reproducing load so what does it really prove??
Im not trying to argue which is better I just want information so i can make up my own mind
#43 · (Edited)
vcyclenut,
Just give him a call....It's a total different type of interface. I would just have to show you on a Video.... You don't put number in it... It use a graph. Also by the Way. FASTCARD had a richer AFR than the PCIII head to head on four gear when it made more power.
Look
PCIII
FASTCARD GEN III
Also Yoamatt is the one selling his PCIII for the FASTCARD GEN III on his 04 R1.
Also I just sent you a PM.
Stan
#46 ·
What happens if you have an ignition module on your bike what do you do.
#47 ·
I have read all the threads and noticed that every body is adding fuel, correct me if I am wrong but can the gen III take away fuel if need be.
#48 ·
I'm curious how this new product bypasses the restrictions on the Factory ECU..... You stated the PCIII can't do anything below a certain rpm. well that's not true at all, it was only referring to 100% throttle opening adjustments.
Also, I'm vary curious why Stan is pimping this product so much?
That said, is this new company a site sponsor? if not they might be getting a bill for sponsorship. If you read the rules clearly on the forum you might be suprised. :)
#49 ·
R1Lover,
I can't belive what you wrote, I thought you were better than that!
Why would you put a Video of the 07 R1 Lag issues, AKRO EVO II????
I bet that you just wanted to help your R1-forum brother's and sister's with this issues. You wanted to help... Same goes for the AKRO EVO II... You just wanted to help. What I'm doing is no different. I just to help R1-forum brother's and sisters. I'm a Network Engineer, I've owen 5 motorcycle in the past 4 years.. Which I love. I just want the best for my R1. Which has Ohlins ttx-36, 25mm front cartridge, Akro EVO II, HID light low and high beams, Pazzo, plug DD, GTYR Gel seat, GTYR seat cal,GTYR air filter, A&R Race Baffle's, FASTCARD GEN III, PCIII, Ignition module, Quick shifter, Blaster tail light, Power 2ct. As you can see I mod the hell out of all my bike.
Also why this product is better for the 07, because it does not use conventional ways in tune IE TPS(PCIII). That's why it's load base. I hope this help you out.
Just look at their notes on there page.
Stan
</IMG></IMG>
#50 ·
will this product work with an igntion module or not. Also what about a quickshifter. I know these prodcuts are piggybacked off of the pc3.:secret:
#51 ·
Stan, please don't get offended, it was not meant to piss you off, you seem to be cool, I just asked the question is all.
You were bagging on the PCIII saying it's useless under 9k or something when in fact that's not true... so I wondered why you loved this new one so much.
The simple fact is that hardly anyone has any experience tuning this new one so that alone will make it next to impossible to get it mapped correctly.
NOT many shops want to waste time learning something new that only a couple people will pay them to tune.
Just my .02 anyway.
#52 ·
http://www.dobeckperformance.com/TF...nce.com/TFI INSTRUCTIONS/Sportbike Tuning/Understanding the pots sport bike.pdf
Simply put, the way i read the .pdf is that the TFI GEN3 modulates the stock ECU fuel output signal according to four simultaneous functions each of which have an adjustable gain.
Note that fuel injection tuning and control philosophies are reasonably sophisticated systems. When you add something like this to an existing system then you have to understand how the standard FI system works AND understand how the add-on works if you want to be able to understand the result of combining the two. These are waveforms not discreet little boxes.
I see people keep saying it is a load based tuning philosophy, i would love to hear about how they are defining this concept of load based tuning. Because it adds different fuel at different RPM? hehe a PC3 can do that and different amounts at different % throttle openings.
The air fuel idle mixture can already be adjusted using the stock ECU, however i note that this is combined with the 4th setting in that .pdf document which sets an RPM which the idle fuel mix algorithm is disabled which is an interesting combination.
#53 ·
R1 Dav3... The link you provided I believe is for Gen II models I think. I may be wrong but it appears Gen III added some wierd blue modes and stuff... unless its just a prettier package to do what there pots on the gen2 did?
This is there Gen III demo...
http://www.dobeckperformance.com/Gen_demo/demo.asp
Note I do NOT have oppinions on these products but I would simply like to know how they have changed over the previous Gen II models. Gen II models even said if you changed your bike enough to not be able to use the stock mapping then it was not for you. Is this still true for GenIII? too bad I can't really find Gen III info expect posts on this forum which seems very odd... could be my search sux.
#54 · (Edited)
