Hey guys,
I'm getting on the Ti bandwagon here and have a few questions:
1. When replacing the OEM bolts with Ti pieces, do I use the same torque spec as the OEM bolt? If not, how do I know what the proper spec is?
2. Do I need any sort of thread locker with the Ti bolts? If so, is Loctite OK or is there something special made just for Ti?
3. Is there any sort of 'lube' or anti-seize that needs to be applied to the Ti bolts before installing them, to keep them from seizing to the OEM parts (i.e. forks, swingarm, subframe, etc.)?
4. How do you know I'm buying quality made fasteners? I'm sure there are many places to buy Ti bolts, but I don't want to spend the $$$ on all of the bolts only to find they are made poorly, i.e. threads cut poorly, out of tolerance pieces, not real Ti, but just a wierd alloy, etc.
5. What is the most respected source for quality Ti replacement bolts? Not the lowest price, but the best quality? I don't want to second guess whether or not a bolt is going to hold as I'm flying down a backroad. I want to replace them and forget about it.
6. How often do you need to re-check the bolts? If the Ti bolts are torqued down properly from the beginning, is there a reason to suspect that they'll loosen or back out over time?
Thanks to all who can provide the answers to the above questions. I'm hoping that the resident Ti addict (rorlow) will chime in. I know Ron would only use the best on his gem of a bike.
Cheers all and enjoy your weekend.
S.
S.
