weird rattle question
1.1K views 5 replies 3 participants last post by  Sabian
hi guys, i have an 07, and when i press the clutch half way in while in neutral the is a rattle coming from lower right side near where the engine oil fill cap is, it only happens in neutral, never in gear, and clutch doesnt slip or anything and shifts fine, is the the slipper clutch making noise?
Press the clutch all the way in....you are only partially engaging it.
Clutches make noise. Bunch of pressure plates being pressed together...you'd make noise too. THe one in your car does it even, difference is, your ear isn't 2 feet away from it.
That is all.
