Well - The New '06 YZF-R1 L.E. is "broken in" - Took a long loop today ....
1 reading
3.4K views 13 replies 10 participants last post by  George P. Buono
Hi Folks,
Changed the oil and filter (though probably un-needed) to capture any clutch bits or related minutia. Then changed the shift-light to ~10.5 k rpm - well enough for now.
The Pirellis Diablo Corsas are well scuffed and feathered in, and the rings are properly seated. When up-shifting at better than 10k rpm, the world has changed The bike is still as delivered (mostly) for now with the exception of a Power Commander with a stock map.
Though I had previously explored 10k rpm, now - as a minimum shift point when cooking - I am riding a different motorcycle.
The forward weight bias and long swing - arm help me see the next turn, they come fast - it does not seem wheelie prone (yet).
After I replaced the front pads with EBC Sintered HH pads, the rear seemed vague. It was not until now that I realized I had completely unloaded the rear while hard breaking - the wheel was barely touching.
Wait until I install the 19x18 Brembo radial master cylinder and dual Goodridge lines to a single double banjo bolt off the master cylinder – the front brake pull will be reduced with no real loss in power. Better control and feedback are the goal.
Thanks Yamaha for the back torque limiting clutch on the L.E.
I have and own a few fast bikes, but I can’t yet find a safe straight long enough to see if it will pull redline in sixth - it needs to be re-geared.
Many reduce the counter-shaft sprocket by one tooth and increase the rear two teeth 16/47T). I dislike reducing the radius the chain travels and went with a three tooth increase (48T) in the rear after a few tries (nost that the Marchesini wheels on the L.E. will not accept a standard R1 sprocket - five studs vs. the standard six for starters).
According to SpeedHealer's gearing calculator, this 17/48T sprocket combo gives me an approximate +13.8 % speedo error and a +7.8 % odometer error. going with the 16/47T sprocket combo, the approximate speedo error is +18.4 % with a +12.2 % odometer error - it is actually a lower final drive, For where and how I ride, the three tooth rear sprocket works well (note that the chain adjustment range allowed me to use the OEM chain - shorter wheelbase now (won’t make a bit of difference).
I have a Power Commander with a stock map installed - helped a bit with the 7-7.5k flat spot - maybe just my imagination. I purchased a Tergonomi "Y-Pipe" to replace the catalyst that I thought (and may now doubt) was cooking my legs in construction zones or traffic - underway - not a problem. But the Tergonomi part is only compatible with their full system. So I went with the Ackrapovic stainless part and their titanium C/F clad suppressor.
In any event, I will need a custom map due to the reduced back-pressure - and the folks here at Hare Racing (Sunnyvale, California) will provide one from some three dyno runs (an authorized DynoJet facility).
And the Termignoni "Y-Pipe" is a component of their full system - and it will not work for my plans.
Solution - go with Ackarpovic oval suppressors - the best choice on this bike and their own "Y-Pipe" - a direct - bolt on to the remaining system.
Power Commmander offers a decent base map for this combination - but in order to get a custom map from the dyno - I need a to log a few more miles on the bike as I am informed that maps change if set too early in the bike's life.
Yep – I too can ride like the Hayden Bros’ (B.S.) – but I am an old man and I seriously doubt I will ever be wanting for a better bike.
All the best to you and yours,
John
San Jose, California
I believe the Akrapovic "Y" pipe and the Termignoni "Y" pipe are identical. I know this because when I ordered my Termignoni system, the "Y" pipe was back-ordered and the service representative advised me to purchase the Akrapovic instead of waiting. The exhaust I want to see on one of those LE's is the Termignoni Rossi Replica can they started offering. It is a shorty side mount that looks pretty nice in pictures I have seen. It comes with a new undertail/antidraft to clean up the rear. I noticed the amount of exhaust produced from the pipes increased dramatically once the Cat was out and the new Y pipe was in. It must breath so much better.
Your bike looks great. I was wondering if you followed the manufacturer's break-in specifications, or if you went a different route? I followed the hard break-in instructions. My friend followed the manufacturer's spec's and I actually had 3 extra HP on the dyno (when both of our bikes were stock) I'm not sure if it was the break-in, but you never know. I broke it in per these instructions:
http://www.mototuneusa.com/break_in_secrets.htm
#6 · (Edited)
'06 Break in and Y-Pipe (Catalyst) replacement ....
Hi Folks - Thanks for the kind words,
Yes, I followed the "Moto-Man" break-in as you have linked. Not just on this bike but others as well. I believe it is the best method.
Decades back in the Trans-Am and Can-Am auto racing daze as a crew chief, we broke in the big-block engines on the dyno - using a very similar method.
But on the track we had to dial in the transmissions, brakes and suspension settings (with Goodyear's help) - that took care of the rest of the package.
I no longer race my bikes on the track - my AMA and AFM days are over. But I ride hard during the week where I can sort my bikes in with minimal risk of incarceration.
Thanks for the info - but I believe the Akrapovik slip-on system and Y-Pipe use the same Yamaha OEM gaskets and clamps - whereas - the Termignoni Y-Pipe is a floating slip fit for a full system - evidenced by the welded-on stainless loop for a linear spring to keep it in place - no gasket or clamp.
It is also much smaller in diameter than the stock '06 R1 exhaust pipe feeding the OEM Y-Pipe and Cat and will not acccept a stock gasket or clamp.
I have the Terignoni Y-Pipe in hand and it will not mate with the stoch R1 exhast system - but is rather intended as a component of their full system. PM me if your interested as it will be hitting the classifieds soon.
Let's hope that the Akrapocik system does as outlined in their line drawings (using the stock R! clamps and exhaust gaskets).
If all else fails, I will simply knock out the ceramic cat internals and use the OEM Y-Pipe. As is - I enjoy the exhaust note of the stock suppressors at full song - and I wear very effictive form-fitted earplugs. I am afraid that the aftermarket C/F Ackrapovik ovals will just be too loud.
As mentioned, to get a custom map on the dyno, I am told the internal baffles of the oem silencers will not allow insertion of the O2 sensor(s).
And yes, I have the best sliders I know of coming from Germany next week, GSG - Moto. Imported Stateside for a number of bikes by this outfit:
http://www.whaccessories.com/Yamaha R1.htm
With no fairing mods required and incredibly stout - the set I have on my '05 FJR1300ABS managed to save me when an idiot in a Xion mini-van decided he wanted the lane I was in on the freeway - about 70 mph.
Saved the bodywork (and probably a lot else) and kept me upright to look things over when we pulled to the roadside. Nearly opened the sheet-metal side of his van like a can opener.
Replaced a few bodywork bits on the FJR for cosmetics and the GSG slider with it's bent aluminum alloy billet mounting bracket/ The damage to his van was nearly $3k USD.
All the best - will keep you posted,
John
YZF-R1 L.E. Nunber 158
Does anyone have a photo of that new side-exit exhaust?
As for the new bike, good on ya brother! It looks great, and sounds like it has an owner that will take good care of it!
