what should Idle AFR be?
2.6K views 4 replies 3 participants last post by  Shifu
I just installed pcv and autotune. I'm still settinG the numbers. I might set my afr 13.0 for a starter and work from there.
What should the idle afr be?
I'm idling at 12.3 afr on 1200rpm.
2013 r1, Mods are Coffman exhaust and bmc filter.
I notice videos on YouTube some is idling around 14afr.
thought mine might be too low....?
Thanks in advance.
I went -7 from 500 to 1500rpm.
now it idles at 1380-1400.
Let me know what you guys think...?
also is there a way I can take out fuel at start up?
Soon it starts or when it's cranking it smells really rich(which I think is part of my start up problem. Takes awhile to start up.)
i generally set it to 13.4AFR @ idle, flashed to idle between 1380-1400rpm as above :thumbup
you do not need to waste all that gas when there's no load on the engine... no point :no
lean hear out a bit... 13.8afr i see from time to time out in the hills and thats about as lean as i like to go
Low revs including the idle use IAP mapping all the way till about 5 % throttle. The target AFR for this area should be between 14-14.5 Consider that lambda 1=14.7. As you said there is no reason to waste fuel there :thumbup
