I've decided to put a more factual post up that we can edit over time until we get all the relevant details in the list below.
(Please note some measurements were made with tape measure but we can tweak it as we go along)
1998-2001 r1 4xv/5jj.
(Front)
-Total distance from spacer to spacer = ???mm
-Spindle length ???mm
-Spindle diameter ??mm
-Disc size 298mm
-Disk bolt pattern 6 x ???mm
-Distance between disc mounting faces ???mm
(Rear)
-Disc size ???mm
2002-2003 r1 - 5pw
(Front)
-Disc size 298mm
-Distance between disc mounting faces 126mm
(Rear)
-Total distance from spacer to spacer = 230mm
-Spindle length 318mm
-Spindle diameter 28mm
-Disc size 220mm
2004-2006 r1 - 5vy
(Front)
-Disc size 320mm
-Disk bolt pattern 5 x ???mm
(Rear)
-Disc size 220mm
2007-2008 r1 - 4c8
(Front)
-Disc size 310mm
(Rear)
-Disc size 220mm
2009-2014 r1- 14b
(Front)
-Disc size 310mm
(Rear)
-Disc size 220mm
2015-2020 r1 - 2cr
(Front)
-Spindle length 262mm
-Disc size 320mm
-Distance between disc mounting faces 122mm
(Rear)
-Total distance from spacer to spacer = 240mm
-Spindle length 345mm
-Disc size 220mm
(Front)
-Disc size 298mm
(Rear)
-Disc size ???mm
2002-2003 r1 - 5pw
(Front)
-Disc size 298mm
(Rear)
-Disc size 220mm
2004-2006 r1 - 5vy
(Front)
-Disc size 320mm
(Rear)
-Disc size 220mm
2007-2008 r1 - 4c8
(Front)
-Disc size 310mm
(Rear)
-Disc size 220mm
2009-2014 r1- 14b
(Front)
-Disc size 310mm
(Rear)
-Disc size 220mm
2015-2020 r1 - 2cr
(Front)
-Disc size 320mm
(Rear)
-Disc size 220mm
