whats the difference between 99 and 00 upper fairing
891 views 10 replies 7 participants last post by  BlaziN R1
how do you tell the difference from a 99 and 00 upper fairing? I'm looking to buy this used one, but the shop doesn't know if its for a 99 or 00. is there anything i can look at to determine this?
the 98-99 upper fairing has a blunter, shorter nose which obviously means that the 00-01 has the sharper nose. i've been personally told that they won't fit each other since you have to buy the proper lights and maybe the mounting bracket. if you're looking at the red color combo, 98-99 had a particular color scheme that is very different from the more popular 00-01 scheme
well the 99 i need looks almost exactly like the 00-01. I figured out the difference. it's barely noticeable, but the black paint that runs up the middle of the fairing on the 00 is wider than the 99 at the nose. the red paint line between the black paint and the headlight is slimmer on the 00-01's. anybody follow what i'm saying?
correct - I have a 99 and the 00-01 - I was told if you want to switch to the 00-01 upper you need the fairing, fairing stay and headlight assemply (and a new windscreen) the 99 has a smaller windscreen than the 00-01s
need more info
Sup all!!
Just ran across this post, here is the deal, i'm putting together a 99 R1 that my brother wrecked and i had no clue about the difference in nose/lights between 98-99 to 00-01, BUT....
The nose i got is off 99 and headlights from 01 friends bike that crashed.. i have not bought a bracket that holds nose, lights in place.. should i buy this bracket for 99? will it all fit together??
please let me know, all advice will be highly appreciated.
Regards,
Ismar
since the healights i got are brand new and i got them for free, then just go trade my 99 nose for a 00-01 nose at a local motorcycle salvage yard? Nose is in great shape just has scrapes but those parts are always repainted before they're put on anyways..
u will need a 00-01 upper fairing stay to fit the 00 nose and headlights, then your 99 gauges wont fit quite right and will need to either cut the hole in the fairing stay bigger, or use spacers so the wire connecting to the gauges will be able to plug in.
<---- Look over there...im puttin a 00-01 front end on my 99
