Where to buy OEM turn signal connections.
2.9K views 9 replies 7 participants last post by  Halo_2
Hey guys, i figured if anyone could help this would be the place.
I recently bought a 2006 R1. The guy that owned it prior to me put after market rear turn signals etc on the bike and butchered the wiring job pretty bad. He cut off the OEM connectors for the turn signals and taped the new wires together. Is there anywhere that sells the OEM connectors so i can get this back to factory wiring?
Thanks,
Any Yamaha dealer can order them for you. Actually, you should be able to find them on eBay pretty easy since Yamaha has used the same OEM connector for the R1/R6 for years.
Thank you for the help!
R1 Aussie and ZdaMan, both of those were what I was looking for!
Luckily I stopped at my local yamaha shop and they had a tail section sitting around from a wrecked R1. So they cut the wires off and sold them to me for 10 bucks.
You can't order these OEM connections from yamaha unless your order the rear part of the wiring harness or possibly even the whole harness.
