Re: Re: Re: defining body steering
Andrew Trevitt said:
I can't find any physics that shows you can move something while solidly attached to it, unless you offset your cg and use that to create a torque-meaning you have to move into position first. I'm thinking of something like a ladder falling over. And, I scared the crap out of myself on Keith's No :bs bike by trying to ride it without moving.
Consider this, Scott: when you push down on a peg, you have to brace yourself against something-say your thigh on the seat, or your knee on the tank. This will make an opposite torque to the one made by your foot on the peg, cancelling out most of the effort.
AT
what if i don't brace myself against the tank.. there will be a resulting unbalanced torque on the body that tries to close the gap between bike and rider.
Any unbalanced peg weighting will result in a force/torque that acts oppposite to the resulting tourque/force the body to the one the body applies on the bike (netwons second law)
but AT your statement that you need to move first inorder to apply torque is not true.. i can start to apply a torque without any displacement.. but by applying any resultant force on the bike... an unbalanced force/torque on you which .. if you were stationary w.r.t to the bike will try to move you.
example.. i'm leaning to the left and the body carries more role rate to the left that the bike.. apply force on left peg.. bodies role rate will reduce.
in pratice you would want to be hanging off quite a bit.. or you need to be rolling(about the role axis) when you try and use B.S... i think it is important that we differentiate movement of CoG with a rate of rate of change of displacement(acceleration)
lets define B.S. this way..
first we establish role, pitch and yaw axis on the bike.
Any steering action that results from an unbalanced torque applied by the rider on the bike along the role axis of the bike.
i think it safely excludes C.S. and possible shifts of body to change weighting on the front and the bike of the bike or lowering/raising CoG actions to change geometry or weight shifts.
at first sight it might seem that using B.S. might result in no changes of line.. since the bike will apply the opposite torque on the rider and the there will be no external torque on the rider/bike system.
the following reasons will result in a increase in lean of the bike/rider system when you us B.S. (in no particular order)
1. trail of the bike will lead to change in steering angle which will lead to bike dropping into the turn some more.. (this is a slow change.. we can get into why if people want to)
2. increased lean angle of the wheels will result in increased camber thrust that leans the bike some more.
3. torque on the gyroscopic momemtum when applied on the role axis will transfer some of it into the yaw direction... while leaned over not only will this result in a tightening of the turn but will also seem to lift the rear a little bit and put some weight on the front.
so when we use B.S. we will see changes in line.. and different demands on front and rear tires compared to using C.S. (which derives most of its sterring traction demands off of the front tire)
we havnt figured out how much of a change in line we can get from B.S. but i hope this offers some explanation into why B.S. might work... but isnt it useful to learn a technique that might be able to change the line without having to use as much traction off of the front?
vishnu
