Cause the $100.00 versions, just plain suck...
http://www.roadracingworld.com/news/article/?article=25781
:iamwithstTito said:I don't get why some people are stingy when it comes to something so important...
:scared I rock an HJC! yikes, I guess this could give me a reason to upgrade to that SUOMY I have always wanted!:thumbupextrakt0r said:Cause the $100.00 versions, just plain suck...
I thought this "eggshell" technique is what they were aiming for.. you know, like when you crack and eggshell, the yoke falls out fine. I have always been under the impression that this is what they were going for. :dunno~R1CrazyTex~ said:...I've seen pictures of the KBC/HJC helmets after a crash and they are cracked like an eggshell or totally split in two...
I TOTALLY disagree and i will explain:01R1RIDA said:I think it is all about how comfortable you want to be. DOT / SNELL are the same for all helmets. Shoei way more comfortable than a KBC.
As long as they have the DOT/ SNELL stamped on it you should be good.
I paid 508.75 for it out the door @ Cycle Gear. I Shoped around and they were all about the same. But I needed it soon so I got it. The guy also threw in a Chrome visor for me $65 so it came out not too bad. I love the helmet though.Klo1320 said:Tex, that is the helmet i am looking to get...Have you seen it for less that $427? That's the best deal I have seen
jamOnerR6 said:I thought this "eggshell" technique is what they were aiming for.. you know, like when you crack and eggshell, the yoke falls out fine. I have always been under the impression that this is what they were going for. :dunno
:lol :lol :lol~R1CrazyTex~ said:"like the way charlotte spins her web"
I always disagree with the "you get what you pay for" argument. If that were all there was to it, you should just get the most expensive and be done with it. I know women like that.flywheel said:Arai all the way!!!!!!!!!!!!!!!!!!!!!!!!!!!! You get what you pay for.
No Twilight said:I always disagree with the "you get what you pay for" argument. If that were all there was to it, you should just get the most expensive and be done with it. I know women like that.
As a geeky enginerd, I like to look at specs, testing, and certs.
DOT is not useful. A good sized tupperware bowl with some foam and a chinstrap could pass that (ok, that's a bit of an exaggeration but not much).
SNELL is much harder to pass and you should always look for Snell approval. Then, if you're still considering a cheaper helmet, go to the snell website and see what they said about it. Some cheap helmets claim Snell approval when they aren't listed there. Some claim to pass when they passed with significant negative comments on the test results.
Finally, try the helmet on and see how it fits. I've noticed that a lot of the cheaper helmets fit well around the cranium (where they are tested) and poorly around the jaw area so they can move on your head and don't protect you well in all kinds of accidents. I suspect that these helmets are designed with the test in mind. The designers/staff engineer (perhaps and engineering summer student???) know where the test impacts the helmet and make sure that it is beefy in that area. So what if other areas have weaknesses.
In Shoei and Arai I have seen no indication of such inconsistent design and I will stick to those two brands.
Finally, I will not wear a flip up style helmet. I have heard rumors of eye-socket damage because of poor crushability of the padding in the eye-socket/hinge area. I don't have any real data to back this up (usually a reason for me to be very skeptical) but it makes sense to my engineering viewpoint so unless I find a test that tested these areas I'll avoid the flip ups.
So I'm currently using a SHOEI TZ1 and I'm idly shopping for a new helmet. I'll probably buy the RX7 Corsair or the X11 in solid blue to match my bike.
--Jerry
so your main concern is ventilation..oook~R1CrazyTex~ said::iamwithst
But I have to admit... I was very stingy on helmets.
"They are all certified Snell/DOT right"<-- what i thought.
As long as its comfortable who cares, it's all the same....
WRONG WRONG WRONG:no :no :no
I purchase the Icon Mainframe<-- good helmet BUT.... vents worked OK, and it was bulky and heavy...
Upgraded to the Shoei RX-1000<---:boobies :rock
Ridiculous venting to the point if it's even slightly cool I have to close them all cause my head gets cold, and it is like wearing a baseball hat it's so light. It's a little short in the chin but I have a big chin/nose so it's all good. :fact
Helmet and Suit are probably the best things one can buy for the expesive part of it.... other than LED red lights to show off the bling!!
So Jerry, are you calling me a woman??? :bashNo Twilight said:If that were all there was to it, you should just get the most expensive and be done with it. I know women like that.
--Jerry
JDPT2 said:so your main concern is ventilation..oook
