Will the R6 "throttle Mod" work on the 2015 R1?
9.3K views 22 replies 10 participants last post by  Roadracer86
could someone who has replaced stock tube measure the diameter?
2006 R6.
Part: 2CO-26240-00. This number is what was on the yamaha part label on the bag the tube came in. Some people in the USA are saying their # is 2C0-26240-00-00 (extra 00).
Colour: White.
Diameter of cable pulley: 40.5mm.
Turn: 1/6.
I was hopeful for this, too. Not only are they the same size, they're the exact same part number! Motion Pro Rev2 kit is 10 times more expensive than the R6 tube, but it'll fix you up and clean up the slop in the throttle as well.
So I'm running down this rabbit hole looking for a 1/5 turn throttle for the R1M that will fit in the stock throttle housing. Has anyone found something that works to shorten the throw? Does the Graves unit reduce the throw or is it a 1/4 turn like the stock tube?
I bought the Motion Pro Rev2 kit and it won't fit with stock bars and Nissin M/C so that isn't an option. Any other suggestions?
