Yamaha R7
5.4K views 20 replies 10 participants last post by  AHB537
Hi guys, I am new to the R1 forum. Hope you don't mind me posting about the R7. I am trying to track down some info (ideally a copy of the YEC kit manual) for the white wire modification. Any help would be appreciated.
Many thanks
Neil
James thanks for the response and the info. Don't suppose you know if the ECU needs reprogramming after this mod do you? Searched ebay for an R7 YEC kit manual but nothing on there at the moment. I have ordered a test coupler adapter, which should allow me to interrogate the ECU and enter codes.
Did you get the attachments you sent from the kit manual or elsewhere?
With regards to the request for pics will take some later today and try to post
Many thanks
Neil
I have a 2000 kit manual I will try to get you. The document I posted came with a bunch of literature and service manual when I bought the bike. There is no info about tuning for the white wire in the manual, (no mention of it I'm pretty sure).
Supposedly the white wire mod was done to mine, but when I pulled the secondary injectors they looked dirty and not from use (minty fresh when you wiped them clean)...
Programming the ecu looks like a real chore with its archaic button mashing interface, something I haven't done yet...my bike is running the same horse power as a late Gen tuned GSXR 750 (on the same dyno) but it's a little on the lean side, the secondaries need to be activated for sure and it could use a proper tune...it would be unreal to ride one of these with a full 160 to the wheel...
#11 ·
Have investigated mine and it has already had the white wire grounded to earth, but the when the ignition is powered on the red light does not flash 5/6 times (supposedly indication that the race mode is enabled and all 8 injectors enabled). Guessing it needs the additional code entered to trigger the race mode for the ECU. Would be great if you could send a copy (electronic or paper, will cover any costs) of the kit manual. Not after 160 but would be nice to gain the extra 20 from enabling all injectors.
#19 ·
:iamwithst
