YEC cam specs 04-06 R1
1 reading
11K views 8 replies 3 participants last post by  .04r1.
Does anyone have the lift and duration specs on the 04-06 YEC cams?
i have an intake cam lying around somewhere. How quickly you need the specs?
I have acquired a set, they just are not here yet. No real rush.....
Thanks bro!
Mind if I ask how much they set you back? New or used?
Thanks.
I found a new set on the WERA board with 2 YEC head gaskets, 2 YES base gaskets and a set of YEC clutch springs for $500 shipped.
Kangaroo,
YEC made a few sets of cams for the 04-06 R1's, including standard lift cams, which your's obviously must be. There are SBK 04 cams, standard lift 04 cams, SBK 05-06 cams and standard lift 05-06 cams. The 04/05-06 cams will all interchange, however the specs are different.
I agree those do seem to0 be the stock lift longer duration set. I have the high lift ones and they are being installed at Lee's right now :rock
Kangaroo,
Here's the cam specs for stock and both types of YEC as well as both versions.
Type
intake duration-lift in mm
exhaust duration-lift in mm
04-06 OEM stock
292-7.6
284-7.5
04 YEC SBK (70 suffix)
286-8.5
288-8.5
04 YEC standard lift (80 suffix)
288-7.6
288-7.5
05-06 YEC SBK (71 suffix)
284-8.9
281-7.7
05-06 YEC standard lift (81 suffix)
292-7.6
285-7.5
