Zero Gravity Windscreen Stickers
6.3K views 9 replies 7 participants last post by  raza1123
I just got a zero gravity DB windscreen for my bike. How can I get rid of the zero gravity stickers? I tried removing one of them, but a residue from the glue was left behind, which is hard to get rid of. Is there any technique (or solvent) I can use to get rid of this?
BTW, the windscreen is great. Definitely less drag (wind resistance) than the factory windscreen.
Peanut Butter!
after you peel the sticker off, rub a good amount of peanut butter on the residue. let it sit for a bit then it will rub right off. Rub carefully as not to make swirl marks. the oil in the peanut butter will remove residue without harming the plastic, cleaner and other chemicals will mess the plastic up
I ordered mine direct from Zero Gravity and ask them to not put any advertising labels on at all...the unit came naked so I didn't have to remove them...if you use some GOOF OFF and a soft cloth it will come off effortlessly...
No...no...no...
This is what I'm talking about...this stuff is designed for that sort of crap...:)
