Hey guys.
Stock '06 R1.
What temp are the cooling fans supposed to come on??
Stock '06 R1.
Uh...the service manual:dundun:Thanks.
I'm more inclined to believe the 220, than the 176. (176? Where did that come from?) LOL
Mark
99 R1
Lol... That says the resistance of coolant temp sensor is 0.29-0.35 kOhms at 80C, that has nothing to do with what temp the fans come on. The electrical resistance changes with temperature, which changes voltage, which is converted into a temperature value by the ECM.
Mine come on at 220F as well, '09 R1
A few months back, I posted a response to the same question and answered "around 220". The OP said his came on at 176 and I had no reason to not believe him. I will put my dunce hat on now...:dundun:Thanks for that clarification.
(I figured 176 sounded absolutely assinine)
Left sideSomeone had posted a link somewhere to install a manual fan switch to a "green & yellow" wire immediately before the relay.
Just looking for a better explanation as to where to find this wire? (i.e. what (side) needs to be removed to access this wire?)
Some folks want to be able to manually switch on the fans at a lower temp to keep the bike from reaching its factory set point of 220.What is the reasoning behind manual fan switches?
I have no idea, probably thread it in to a metal sleeve and connect the sleeve between two roubber coolant hoses. I haven't looked this far in to it yet.Where do you install the Zirgo Temp Sensor Fan Switch?? Is there a readily available "port" ?
