as the title says, when i'm riding on the streets it can reach up to 230F and the fan always kicks in on red light, is this normal?
After you change the oil, it will drip onto the headers a little during the change. Even if you wipe it off you will leave some behind. It's the nature of oil. If you could wipe it all off totally, I'd be worried about the type of oil you use. With that said, when you run the bike, it will burn the remainder off, and it will smell.05 r1racer said:I notice it too. Did you just got an oil change done? I did mine over the weekend and it smells funny too. I have cleaned up my drips fm the oil filter and the drain bolt. Not sure what cause it. Any 1 else?
cool, is there anything i can do to prevent the temp from going so high besides riding it, i checked my coolant level and it's always normal also, i'm doing the next oil change myself, thinking of using amsoil, should i use 15W-50????Sabian said:After you change the oil, it will drip onto the headers a little during the change. Even if you wipe it off you will leave some behind. It's the nature of oil. If you could wipe it all off totally, I'd be worried about the type of oil you use. With that said, when you run the bike, it will burn the remainder off, and it will smell.
As for just a smell in general. Depending on where you ride, you could be spitting stuff up from the front wheel onto the headers and it will bake off.
It's not that big a deal, just ride the bike.
OMG....10/30 or 20/40 is what the MANUAL recomends. if you are worried about heat, don't go with a thicker oil. If you run a little thinner oil she will run "cooler" (less friction) or as the theory goes. Just watch to make sure you dont' have any slipage. I run 10/30 in mine, but mostly because it's winter up here part of the year and I don't want thick shit in there.SQUID1 said:what about the oil question.
If you read the thread, and any number of others, you will find that your bike running at 200 degrees while sitting in traffic is normal. If you arn't getting a lot of airflow, such as stopping for the garage, or riding slowly through your residential area...it will heat up. As for the 235 after the bike is off...every engine in the known world does this. The hottest time for a motor is after you turned it off. Coolant needs to be pumped through the engine to extract the heat...and if the motor is off, the coolant is not going through the motor...it's now just sitting in the tubes and the radiator. Runnign the fan with the motor off will cool off your water temp in your radiator only...does nothing for your motor. As a matter of fact, put your hand next to the fans and feel the heat that is being blown onto your engine...doesn't really do a lot. You're bike is fine...they've been this way for two years now, and I'm willing to bet the 06's are the same.street277 said:I have the same problem. i put a new radiator hose on the bike since i busted the stock one cuz the geniuses at yamaha had to weld on my freakin oil filter. so with that said, i got a new radiator hose and installed it and added some coolant ran it for a while and i noticed that it was running at 200+ at a stop without even riding it at all after starting it. i put all coolant not water mixed in. any ideas? i brought the bike home just rite now after a 2mile ride and i stoped and opened my garage and it reached 225F and after i turned it off it went up to 232F and den 235F and this is after i turned it off. so i left the key on.. and let the fan run. wat can it be?? any ideas?
Thanx
I'LL Save you Sabian!!!!! :lol Always follow the manufacture reccomendations, they don't spend all that money on R&D. They will always err on the safe side due to liability concerns.. Oh Yeah... JuSt rIdE!!:lolstreet277 said:Thanks a lot guys I appreciate the help. And as far as 100% coolant goes. I read the yamacool coolant bottle and it says its 60/40 60% coolant and 40% distilled water should that be okay? Thanks
