So I just installed Vortex rearsets on my 2005 R1. I'm running standard shift and I have the shift rod going through the frame (like stock). I'm using the 9.75" Vortex supplied shift rod. The shift knuckle is at a 90 degree angle from the shift rod.
I can shift from neutral up through the gears hearing the "click" and shift down to neutral but I can't get it into first gear. I never had problems with the stock rearsets.
Any ideas as to what the problem is? Anyone else using Vortex adjustable rearsets in standard shift on a 04-06 R1 running the shift rod through the frame? Which shift rod are you using? The 9.75" or the 10.5"?
Thanks! :thumbup
Thanks! :thumbup
