I recently purchased a 2007 R1 from a friend. It has 15,900 miles on it. I had it idling in my garage when I realized that it was running hot. The temp got up to 215-220 before the fans kicked on. I was worried about the engine getting damaged so, I cut the bike off. I have seen some posts from people with this issue.
I will need to visually inspect some of the cooling system components to make sure there isn't a problem with the hoses, thermostat or expansion tank. FYI: this will be my first time working on a motorcycle.
what common failures does this bike's cooling system have. I'll check those first.
Does anyone know if there is any aftermarket thermostat that will fit the R1 and engage/open at a lower temp?
Is there a guide to tap into the fan wiring and install a fan over ride? I want to have a switch/button I can use when I want the fans on.
any other suggestions?
