09 R1 - First Track Ride
3.5K views 55 replies 18 participants last post by  shaun777
Did my first laps on the track in anger yesterday. We ran the track sessions for Yamaha SA's dealer day at the Zwartkops Raceway, 50km north of Johannesburg, so not all the laps were flat out, as we marshalled and instructed riders, but we did get to do some quick laps in between.
Yamaha SA sponsor our track school, so in return we run all their on track events. Yes, free R1's:rock
Man I love this bike, it's awesome.
Back on the track on Sunday, at the Phaksia track.
All pics taken by Johan Engelbrecht www.trackdayphotos.co.za
Arno, Dave's is the blue one.
Lucky, hmmm:cool:, we've worked really hard to get to this position, Yamaha get their exposure through us and the California Superbike School, and also take their pound of flesh when they need help with any event (which we then do for free). It's a happy, mutual arrangement we've got with them.
There's talk of another R-Series day, but not finalised yet.
Unfortunately they are expensive here, thanks to the strong Yen, but man it's worth it.
Who is this????
#16 · (Edited)
That's the front tire. Sag all set to my weight with my riding kit on. The front's done about 1000km on the track, so I figured it was just used up. It only looked like that at the very end of the day, when I also equaled my best lap time at Phakisa. So looking forward to going back with new rubber and improving.
Any ideas what would cause the front to do that, other than it just being old???
BTW, the rear tire wears beautifully, no tears, just nice & smooth
#21 ·
:rock:rock
You are close on the sag nummbers but I would personally set it up at 40 mm front and 30 mm rear for rider sag. I check static but rider is most important. If the difference is much more than 10 mm then you have too much stiction. Nonetheless, you should back out of the rebound a bit. That's too much! You might get the front updated with Oglins new big piston kit with a half less stiffness. For example if the bike comes with a 9.5 then you would get a 9.0 but you will need to verify this first. You might do the same with the rear shock spring. You are close but I think you are over-compensating with the rebound.
#31 ·
Yes, this is why I said to check the rebound in the first place. There is a general concensus here.... I assume you have your tires properly inflated, etc but I still think you have too little sag. 40 mm front 30 mm rear is ideal and you should not want to use up all of your travel at the front. You need to leave about 10 mm still unused at the bottom of the fork.
#33 ·
I think the tires are tearing because you are obviously not using warmers to heat the whole tire, thereby causing it to shred away from the inner carcass. Try using warmers and if you indeed are, check the tire temps before and after a session. Your warmers might not be hitting the appropriate temps.
#34 ·
Even without warmers all together he shouldn't be seeing that kind of tearing. I few laps in and he should be up to temp. Unless it he's doing trackdays in sub 50* weather...and in that case, warmers aren't helping you anyway. hahaha.
Again, I say you check your tire pressure COLD and then right off the track and observe the change. You should see an increase more than 3-4psi. That looks alot like cold tearing
http://feelthetrack.com/tire-wear.html
#35 ·
fiveoh, I'm not going to get into a pissing match with you on here. I gave the guy the advice I use and I give to every other person whose bike I set up. I'm plenty fast and I use this setup advice myself. I learned a good deal of this setup from Dave Moss of Catalyst Reaction and his advice has served me well. Looking at his tire I see rebound tear. What do you see? I personally think he should have a bit more sag and not use all the fork travel available. If you have a better idea, share it but don't criticize my advice....maybe it's you that is misguided...ever think of that?
#38 ·
Whoa there fellas, no need for handbags at dawn:)
To go through all the suggestions/comments. Tire were hot, used warmers and it was a hot day, so I don't think it's the cold tear.
I did check the rebound again, and I agree it did come back too slow, so I've taken back 4 clicks to let it rebound quicker.
Using all the travel, there is about 10mm left over...
You're most kind, 180lbs, .... try 235lbs, and no fat jokes please....
I'll be at Kyalami tomorrow, new tires, so let's see how it goes....
#39 ·
Oh well I stand corrected. I must have been high that day. You will need to go up a spring rate most likely. Can you tell me where the spring preload is currently as well as rebound and compression front and rear?
For some reason I thought you were 180 lbs but I help a lot of people on several different forums so I must have my hairs crossed. For 235 you will most certainly need a stiffer spring but I don't know what the spring rates are on the 2009 R1. I do some checking around....
Anyone else know? I know Ducati's 1098 is 9.5 N/mm and 80 N/mm at the rear, which is a weird combination. I am 205 with full gear and I have gone to a 10.0 N/mm front with reduced offset triples. At the rear I went to a shortened TTX with 100 N/mm spring and a flat linkage...
With my '04 ZX-10R I went with a 10 N/mm front Ohlins spring and a PR46XLS rear shock using stock linkage and 100 N/mm spring.
Here is an older picture, I need to get one up of the newly prepped 1098...
#40 ·
Ok, I did some digging and I am still not sure what the R1 has from the showroom, however, I have found what is available from Yamaha's Racing Division.
Fork Springs
- 9.5 N/mm P/N: 14B-23141-85
-10.0 N/mm P/N: 14B-23141-80
-10.5 N/mm P/N: 14B-23141-75
-11.0 N/mm P/N: 14B-23141-70
Shock Spring
- 98 N/mm P/N: 14B-22222-80
-103 N/mm P/N: 14B-22222-75
-108 N/mm P/N: 14B-22222-70
These parts are of course for use with oem fork and shock. You would have to find out where you can order these YEC Racing Parts and then get a shop to swap them out.
As a rule of thumb a 5 k/g difference would be used for a 20 lb difference in rider weight. I can't tell you where I think you will need to be until I find out where your preload is and what the stock springs are... But I'll find out those details soon enough!
-Brian
#42 ·
Weight distribution: '09 is 12kg heavier on the front compared to the '07.
Whereas i used 0.925 on the '07 i had insane chatter all the way through with the stock 0.95 springs in the fast corners. Put in 1.025 now, testing on monday. Onboard cam mounted in the meanwhile too :)
Cross plane makes it even easier to slide around compared to the '07.
Grunt coming out of the turns s sweet, she runs hot though, putting on a bigger radiator soon.
