Hello All,
I just got an awesome 2000 R1 that I am trying to get it back to the way it should be... There is a couple things the previous owner did that I don't agree with.. Working on the cooling system right now.. He put the fan on a switch, So the fan runs constant unless you switch it off ofcourse.. I don't want the fan to run all the time, Only as needed, So I would like to get it wired the way it is supposed to be.. I think he just used the two wires that go to the switch, But I am not sure..
Out of the two wires that go to the switch on the radiator should one of them be hot or not? I am going to test the switch in a little bit.. I am thinking he had a problem with temp switch but not sure yet..
Also on the speedo cluster, It always says "Lo" and does not display temp.. Does the cluster get it's reading from the same switch on the radiator?
Thanks,
Ant...
Thanks,
Ant...
