2002 r1 firing order
7.7K views 4 replies 3 participants last post by  turbobanshee535
Hi all,i'm looking to find which cyl. 1 and what the firing order is,and if runs on wasted spark,or each cyl. fires on its owen compression stroke.I'm makeing a project and it has no wiring with it or ignition system.Thanks for your time.
firing is a wasted spark system. 1 and 4 fire same time, 2 and 3 at same time. sitting on bike, # 1 is on left, #4 is on right. not sure if this helps all u need
i dont think the 02 r1 have a wasted spark system:) only the carbed models used it. if i remember right , the 02 model have a coil on each plug.
anyway , the firing order is 1-3-4-2
thanks.have had a r1 top end apart ?im wondering if my cams are in timing.how do you if there in proper timing?there is one little dot on both the cam gears.are they to meet each other ? i now that on a twin cam car they are to meet when putting it together.i hope you can help me thanks...
