I recently bought an 2009 R1, but I don't know if the valves were checked or adjusted. So I'm asking if it is possible to hear the valves?
I could upload a clip.
Wait...09 has a slipper clutch?Likely no, you can't hear them unless they are way way way out.
How many miles on the bike? I think the service interval is like 25k miles.
The sound you are probably hearing is the clutch rattle that is totally normal, as it is a slipper clutch.
The big runs so much smoother, faster, and its more responsive overall. For example, when downshift into a corner in a stock configuration, the rear tends to slide from side to side a bit; however, when flashed the bike tends to stay in a straight-line thus allowing for quicker deceleration into corner. I believe it worth it! It's like having a brand new bike! Give it a shot and if you do not like it, flash the ECU back into stock configuration. If you were to undo the flash, you'd be the first person to prefer stock bike.It has 30k miles. My max speed was around 95mph and I never go past 9k rpm, usually to about 7-8 k rpm, I'm still scared of the power. What does flashing do, increase power?
