2023 R1- looking for more mod ideas
14K views 21 replies 16 participants last post by  CBat
I bought this bike in January and have barely gotten to ride it because of snow. Spring is right around the corner and i am so excited. While I wait, I'm just adding little mods here and there to hold me over. 2023 R1 and looking for more tasteful mod ideas...this bike will eventually be tracked, but not for awhile:
-ECU flash
-3/4 Akro titanium exhaust
-gold CRG levers, shorty brake
-carbon tank protector
-New Rage fender elminator
-ECU flash
View attachment 1028277 View attachment 1028278
If you’re going to be tracking it I’d
upgrade the brakes, Yamaha looks like they cheated out and used the same brake calipers they’ve been using for years . They look like what my 2013 has.
#18 ·
That is basically what I did to mine, carbon accents! I got them from RPM carbon as nobody had fullsix pieces in stock. RPM fit well, only needed to make one clip hole bigger and the clear coat needed a paint correction because of swirls. Here’s what I did for some reference! love the blue btw!
how long did you have to wait for your AR exhaust? mine is still in limbo..
#21 · (Edited)
So far I’ve had mine since the end of July
AkrapoviÄŤ, full titanium exhaust
Race spec axle nuts and pinch bolts magnetic drain plug and oil fill cap all in Ti all safety wired
Servo delete
Flash tune form 2wheel dyno works
Tapped the pre drilled hole for GP shift
Lightech chain adjusters
Attack swing arm lifters with toe guard
JL Fender eliminator with integrated tail, light and blinkers tucked up on the two wings of the sun frame
Graves o2 block off plates
Stop grip icon design tank pads
GB racing case covers
Gilles tooling sprocket cover
Evoltech radiator and oil cooler guards.
Next will be attack rearsets
And ether a Penske 8987 shock or Olin’s ttx
And GP suspension fork cartridge inserts.
