Hello,
at first I want to say that this is the best forum, especially for getting technical information. I've read and learned a lot here, thank you all :bow
We are racing small hydroplanes in germany and we found that the best engine for our rules (construction of engine at least 10years ago, max 1l, only carburated) is a 98-01 R1 engine.
This is the boat:
We could win the european championship this year and the information from this forum helped us a lot!
We changed the gearing and removed the clutch since we arent allowed to shift, so there is a need for a wide power band from ~7500rpm to (at the moment) around 12800rpm.
The engine runs with a ivan-like-modified airbox with k&n filter, a dynojet kit with DJ140 main jets, ported head, fully programmable ignition with 02-03 gnition coils and a self made exhaust system which is very "open" (sorry for my bad english btw). The CR was stock but will be raised for this season by milling the head about 0.35mm. The crancshaft is dynamically balanced, the pistons and rods all have the same weight. We don't want to rev over 13000 since there is not that much money available :no
So here comes the question (finally
the original cams were degreed to 107/101. We have no possibility to test the engine on a dyno so what we do is always think about it, change 1 thing and test it on the water which is really time-consuming.
There is always a small "hole" in the power band at around 8000-9000rpm (which i have seen on many dyno charts w/o exup system, too).
There is no interest in power <7000/min. What would you advise us to do to get more power from 8000 on but without losing top-end power?
How does the open exhaust affect exhaust cam timing? Since the gas can exhaust easy can we retard the exhaust cam and the intake cam to get more power in the desired range?
I thought about 109/100 or something like that. Would this intake timing make the hole even worse?
I just need a bit theory and experience from you guys esp. how an open intake and exhaust will affect the gas flow and the needed cam timings.
Don't get me wrong, this is moaning on a high level since the engine pulls like mad above 9000rpm which gave us a top speed advantage of nearly 10km/h. But we always need to get better :hammer:
Thanks to all who read till here
This is the boat:
