Does anyone recognize what make or model the exhaust can is in the attached pictures
I think it is messing with my engine running
Basically the bike chokes and gasps for air or fuel in very specific conditions
When hot - above 70 degrees c
when trying to pull away from a stop - traffic light or junction
Just after riding fast or at high rpm or for a long period
It just kinda bogs down when trying to pull away, if you open the throttle fully it dies and is a bitch to start again - need jus the right amount of throttle to fire it up again.
You need to delicately coax it way from a standstill with out opening her up to much
I have stripped the carbs and cleaned al the pins jets, housing and chambers. balanced the carbs with vacuum gages (which helped improve the problem)
Air and fuel filter are new
Previous owner told me he replaced the plugs
Fuel pump seems ok, haven't measure pressure though. The only thing I notice is that it makes a knocking / ticking noise when its building up pressure
Is that normal?
So that leaves the aftermarket slip on
There are no markings on it, I can see the out line of what was once an oval sticker on it.
I want to find out if the carbs should be re-jetted and if there are any special tuning conditions required
at the moment the pilot screws are set to 3 turns out, the engine seems to run best at that setting
Any help is greatly appreciated
Many thanks
Is that normal?
Many thanks
