Is the steering damper on a 2007 R1 adjustable or is it self adjusting with speed? If it is adjustable, where is the full stiff/full loose adjustment at?
Are you a site sponsor, and do you offer special rates for the Forum Members?If your looking for GPR]
My concern right off the bat is how the hell did that rod get bent like that? That is a decent diameter stainless rod that would have to had taken a serious hit to the front end or tank slap. I would be concerned that the front forks or wheel was bent. Those rims are about as soft as warm butter and easily bend just popping wheelies or hitting potholes let alone taking any sort of an impact from a front end collision or violent tank slap session. I'd recommend putting both forks and wheel on truing stand to check for straightness and balance. I'd check fork oil as well, if that bike was ridden hard enough to blow out the damper oil all the rest is toast as well if not recently replaced. Don't expect much performance from your forks if the oil is shot. You may have just beefed up the damper with heavy enough oil to mask the real causing the front end vibration. I have never heard of anyone requiring 30w damper oil to eliminate vibrations. I bet there is other underlying issues or maintenance needing attention still.Resurrecting this old thread, but whatever...
When I removed the steering damper, besides a slight bend in the rod (which didn't affect anything)
-Dave
