Hey guys, I've been working on this problem for a few months & searched all over the forums with not much luck. Here is the story...
Bought the bike off craigslist with about 1000 miles on it 8/26/12. Never noticed any starting problem other than the cct which was swapped out under factory recall a month later. I've flashed the ecu with the flashtune interface a few times, BMC filter with air box mod, AIS smog plates, M4 y-pipe, Two Bros slip-ons, Moty Design 8 cell lithium battery (even though the oem batt still read 12.4v), & the coolant has been replaced with water/water wetter mix. Also have watsen signals & motodynamics integrated tail light if that makes a difference. After reading about the starter issues I removed & disassembled mine only to find out it was in great working condition. Next removed the cam cover to check that sensor but it was also good. Currently have 6k miles on the bike & the problem seems to be electrical & cold related & I'm pretty much stuck. Any suggestions???
http://youtu.be/xCvf76E1G9k
<iframe width="420" height="315" src="http://www.youtube.com/embed/xCvf76E1G9k" frameborder="0" allowfullscreen></iframe>
