This is an appeal to anyone who may have a possible solution to this problem that I am having.
First of all, this forum rocks!
It is starting to turn nice (55 degrees in Utah).
Pulled the cover off the bike (which hasn't started for a couple months even when it did start, 2 months prior, it was only for 10 minutes at a time to keep it from seizing).
I place a new battery in it today.
After changing the oil and filter.
Bike will not start.
No power to instrument cluster.
No lights, no clicking, no nothing.
Battery shows 12.8 V and is brand spanking new.
When I hook up the leads, it shows 12.8 V.
When I turn the ignition to on, leads drop to 0.8 V.
Turn the ignition back to off, battery leads immediately jump back to 12.8 V.
If the starter relay/solenoid is bad, would I get instrument cluster working?
Main fuse is good (metered it).
All fuses in the fuse box check out (metered them).
It's like there's not a bike there at all.
Any input is welcome.
BTW, I unplugged the Gorilla Alarm (tried it both ways, same results).
Thanks in advance.
Thanks in advance.
