Description of EXUPs workcycle (2007)
I finaly put the EXUP valv of the 2007 R1 to the test to see what it really does...
I found out it has a total movement range of 100 degrees.
However, the biggest surprise was that Its actual work range is only 20 degrees.
As soon as the engine fires up the EXUP open to 70deg and stays there at idle (1200rpm) and is fully open at 3250rpm and above... That's all it does.
No difference if engine braking, which gears are selected, warm, cold, pulled clutch, brake applied, nothing, just the rpm moves it.
In the same process i removed the EXUP butterflies and put in special made plugs where the shaft bearings where before to get a flush surface on the inside of the pipe.
I felt absolutely no difference, at least not on the negative side.
Think of it like this, the engine run at 3250rpm and the EXUP is now fully open, how much exh..gas must the pipe let through at 13500rpm without restricting too much??
The tiny volume of exh..gas the engine produce between 1200rpm and 3250 must be far less than the <20 to 0% restriction the valve make in that span.
I won't draw any conclusions of this, just present the facts.
(-07 R1, European model)
