Okay so I got this motor from a wrecker. I'm curious and wanted to learn how this engine was put together so I'd be more familiar with my beloved R1s. I'm more interested in the internal components and what is happening when I push the start button. I took some pics so enjoy. :thumbup
This is the motor dropped. The pics are as follows:
1. From the manual
2. From the left side minus generator cover
3. From the back
4. From the right
To split the engine cases, you need to get to it from the bottom so you need to flip the motor upside down. As the cylinder head cover is not going to hold the weight plus offer a flat platform I would need, I followed the instructions on removing the cylinder head.
5. From the manual, remove cylinder head cover - 6 5mm allen bolts
6. Remove spark plugs - 16mm socket and grabber
7. Good time to inspect plugs and see how the engine's doing. These need replacing.
note: don't forget to remove the cam chain guide on the inside of the cover
1. From the manual
3. From the back
4. From the right
