Is it ok to have a higher resistance than spec? Does a lower resistance than spec mean weak spark?
Primary coil resistance spec is 1.19 - 1.61 Ohms. All of mine are at 1.80. Is this a bad thing? Do I need to replace all four coils?
Secondary coil resistance spec is 8.5 - 11.5 K-Ohms. One of mine is at 8.35 while all others are in the 9.6 - 9.7 range. Is 8.35 far enough out of spec to cause weak spark and cause my R1 to sound like a V-twin?
Plugs looked good when I pulled them.
Thanks for any help.
More detailed post in the Mechanical/Help section but not sure how much traffic that gets:
http://www.r1-forum.com/forums/showthread.php?t=240496
