Wheres your weight ment to be mainly? On the inside peg, or your leg against the tank?
Just always feels uncomfortable to me!
Think about it for a minute. If you apply pressure on the inside peg what do you think can happen to the rear tire? Your knee will hit the ground with a lot more pressure which results in your rear tire lifting. Thus you lose rear tire traction which results in a lowside....unless at the point you lose traction you chop the throttle which then can result in a high side. Believe me....it gets ugly.I have heard so many people say that pressing on the outside pegs gives a rear-grip bias and pressing on the inside pegs gives a front-grip bias. I'd like to hear why people think this is. I have a couple ideas as to why people may believe this. However, I think it is more of a percieved change in grip bias rather than an actual change. For instance, how could you possibly effect total rear grip by pushing off the tank with your knee to add force to the outside peg?
Your uncomfortable with having sex with females, but not males. 2 different things.:epimp:lol @Paytheon...
If you're uncomfortable leaning or the position you're in while leaning. 2 different things.
Well now this is what I mean by percieved traction. I don't totally believe that what you are describing increases traction at all. However, if you do load up the inside peg and do end up losing traction, I can see the loss of traction being far more dramatic than if you were to load up the outside peg. The attachment point of your body doesn't have any real effect as far as i'm concerned. The overall position of your body decides where the weight is applied with respect to the motorcycle. For instance, take a car engine. If you were to keep the engine in the exact same spot but move it's mounting points forward, you didn't change the weight distribution at all (aside from the weight of the mounts being moved of course).If you do any mountain biking or motocrossing, you'd understand the leverage that is going into this process. Your ouside arm is pulling on the bar backwards and upwards while the inside is pushing forward and downwards, read countersteer. If you weigh the inside foot, your pushing your back tire down and away from the tire's traction plane. IF you weigh the outside of the foot, pushing down, then you are pushing the tire into the ground and perpendicular.
Im not racing anybody, im too brittle right now....
Kangaroo has asked me to post this picture of me sliding the rear in a turn, Im doing about 125mph thru here, I really started pushing down on the outside peg here, I didnt crash and I didnt chop the throttle either
