Hmmm,
Hopefully SSR1 will chip in very soon
Engine was to be turned over for the first time today after a professional rebuild.
Fuel, check=good supply and running to the carbs.
Compression, check=good compression, cranked engine over a couple of times to build up oil pressure. Sucks well when you place hand over carb trumpet.
Spark= Nil, have dynatek twin output coils and 8mm dynatek leads, have double checked and have correct coils.
I'm Mythed... have removed 2 leads and attatched 2 spare plugs, which i then grounded to the chassis, still no spark.
Everything electrically was tested recently and there were no problems with the multimeter results.
Have i caused this possibly by bypassing the clutch/sidestand switch..?
Id have said no, because when that safety circuit is activated you can not even turn the engine over!!!
Help please...
Help please...
