So I had the infamous stator failure....bits everywhere in the engine, making knocking noises found magnet fragments all the way in the cylinder block, decided to rebuild and clean anything and everything.
Broke it down to the big end bearings, replaced all necessary "failure" parts. Cam chain good, tensioner good, cams good, Pistons good minor carbon build but no oil burn, oil pump good, water pump minor rust in tubing but not failing. Any who below is pics of the progress and video with fairing was the day before I tore down, video with tank up is day I ended the rebuild. Any help is appreciated.
Replaced with 06 clutch and clutch boss
Replaced with 06 stator rotor
Things I think may be:
1. Timing off some how
2. Starter
3. Spark plug wires? Brand new spark plugs ~1000 miles
4. Fuel pump?
5. Fuel lines?
Thanks everyone
2. Starter
4. Fuel pump?
5. Fuel lines?
Thanks everyone
