I figured out why my battery wouldn't charge. After removing the Stator cover, I saw broken pieces of Magnets everywhere. All the magnets inside the Rotor are destroyed 100%. I pulled the oil pan and found magnets everywhere. Oil Filter was full of magnets. Magnet pieces on starter gear.
So, the dealer said I have to pull the engine and flush it 100% to get them all out. They said my Primary Drive Gear is damaged because of the magnets. They said I can just flush the engine and it will run fine but will have a knocking sound unless I replace the Crank Shaft.
I'm in need of advice from any of you who can give me the best way to skip removing the engine. I have removed the following:
Gas Tank, Tail, Full Exhaust, Oil Pan, Rotor/Stator, Starter gear, Clutch, Air Box.
I see on the bottom of the engine where it can be removed. Not sure if this will expose the crank so I can clean it out without removing the engine. I would have to remove the oil pan, a side panel ((Left side)(Timing Chain)).
Any advice would be awesome. Sure wish it wasn't MAGNETIC or I would flush it all out.
