Signal Fuse Keeps Blowing
3.7K views 7 replies 7 participants last post by  Alnoaimi
For some reason my signal fuse keeps blowing after installing an integrated tail light, and flush mount signals on my 07 R1. It only blows when i hit the rear brake and the brake light dosent even light up when i hit the front brake. I checked all the wiring and it all seems to be fine. I tried puttin back the stock light and it does the same thing. Wut could this be and why is it only blowing when i hit the rear brake????? Please Help.....
Easy Dude.....
Dude there are two wires touching each other... Im sure of that, my bike did that when i fixed the integrated tail light and Hot boddies front signals...
Another thing, Did u fix the resistor ( the white Trainagles that comes with the tail light) ?
Re-open the connections... Make sure that the blk wire goes to earth..and its not touching the +ve wire then let me know...
The little click noise is just the switch to turn ur lights on and off, the switch won't be burned up without wires being burned too. But thats what fuses are for. If the brake lights worked before you changed the lights and not after than u did something wrong in the process. Probably an uncovered or pinched wire somewhere.
Hello
Dont know if you have sorted this problem , but I have the same one and I think its down to the REAR brake light switch .
Kept blowing signal fuse today .
Took rear switch off and it was shitty inside and the brown connector was full of water (uk weather and too much washing !!!) .
I cleaned it out and sprayed it with WD 40 and tried it again .
The fuse didnt blow but the spring on the switch/ lever got hot .
So I think I have a short in the switch .
Am ordering a new switch tomorrow and will hopefully sort this problem out .
Hope this helps
John S ( UK R1 05 , GPZ 900 R 94 , DRZ 400 00 .)
what do you guys mean by switch? where is the switch located on the 07 r1? Is it under the passanger seat in the cargo space? I have sort of the same problem as you guys but my headlights and highbeam and my display lights have went out as well...turning signals work fine but the brake light only comes on when i hit the breaks...any ideas?
