timing rotor bolt torque specs
6K views 5 replies 2 participants last post by  kwcomp
I need the torque spec of the bolt holding the timing rotor to the crank. I have a haynes manual and it says its at the beginning of the chapter but i look a hundred times and not there. The link in the torque specs sticky doesn't work for me and nothing showed up when i searched its for an 00 thanks
thank you but im not seeing it there either i must be retarded, its the timing rotor bolt. It holds The sprocket which turns the timing chain and the rotor that closes the pick up coil. not the generator rotor thats the one the hold the flywheel/stator, and if im totally wrong tell me and i'll torque it to that, but i don't think its on that reference thank you for your time.
