Tips on removing mid fairing 04/05
4.8K views 15 replies 9 participants last post by  tdah1
New bike. Im a wiz at dissasembling my R6 but my R1 is different. i know that i had to learn some things the hard way on my R6 as far as uninstalling fairings and such... can someone give me a heads-up on taking the mids off. going to be installing flushmounts tonight.
#2 · (Edited)
Remove the visible 1/4 turn fasteners on the Side Cowlings, there's 6 or 7 per side, some come out and some are "washered" on from the other side, and stay on, so don't force them out.
Then remove the Side Cowling Inner Panel, this is in 2 pieces split up the middle, the black panels above the front fender, there's 3 push in clips, and 4 screwdriver clips and some velcro, remove the side cowling inner panels. Also you must remove the 2 upper 1/4 turn fasteners on the Bottom Cowling Front Cover.
Now after you have the 1/4 turn fasteners removed you can begin to wiggle the Side Cowling off from the bike, rear first. The front of the cowls that go underneath the lights have a series of interlocking pats under there and you have to slide the fairing off toward the front of the bike. One the fairing clips out you can unattach the turn signal connector and the fairing is free.
If you get stuck at any point you'll just have to play with it, it took me a few times and some experimenting to be comfortable taking it off, and still sometimes I have difficulty lining up the tabs under the light. It is difficult because the ram air ducts ar on this fairing so you can easily misalign the ram
yeah I kinda like twist it forward and up so that part follows the contour under the light, it's surprising how fast it pops out. One day I was having a hell of a time and decided to try....I haven't been able to put it on like that though only off......It's still a bitch.
#11 ·
thanks for the info... i tried to take mine off the other day and gave up... it such a biatch... surely they could have made it easier... my old cbr was a 1 minute job to get it off...
subscribed to this thread. i'm installing my graves flushmounts this weekend hopefully. =)
