somewhere i saw post with info on gearing and theoretical top speed at redline. cant remember, but i think is was suppose to be like 192(without aero, drag and real world power to get to that speed). dunno have to see if i can find post. course stock bike wont pull those types of figures in real world conditions on road.
or are u wanting to know what actual gps top speed of bike on red line would be?
a friend of mine has a pocket GPS.. I was thinking of using that.. with the mods I have.. I can top 6th out no problem.. I was just kinda curious.. lol.. I'm running 6th almost up to 13,800 on my tach.. on the Dyno it's really about 13,500.. and it's not dropping at all..
So to get your speed at 13500 rpm in 6th:
13500 / (65/43 * 33/26 * 45/17) * rear tire rolling circumference * 60 / 100000 = kmh.
I am running on bridgestone slicks with a diameter of 645 mm (circumference = pi * 645mm) , so with stock gearing that would be 323 kmh in 6. at 13500 rpm.
I'm going to use the GPS next weekend.. right now I'm down 1 in the front.. I've used it one time before.. and I only got to top of 5th.. and it said highest speed was 172
with -1 in front.. it might actually run little faster than stock front...if bike is all stock. but if u have pipes, pc and such. it will hurt top end by 8-10 mph with -1. not that u will get full 8-10 if u go back stock. lotsa variables there. let us know how it does
on an 04 motor (put down 152hp) I pulled 181mph via GPS with +1 rear sprocket.
on an 07 motor (put down 160hp) I pulled 186mph via GPS with +1 rear sprocket.
down one in the front will greatly impact your top speed but if you don't have the motor to pull the stock gearing then it may do you some good (as 1longR1 mentioned).
you'll also need good form to limit drag, if you're head is up and causing bad aero then you will certainly get a slower speed.
iv managed 178mph on my 04, i think my spare tyre probly accounts for some lost speed though
Related Threads
posts
6M
members
162K
Since
2001
