Skanky said:
Thomas - that's a good thought, but is it even possible for the shocks to articulate more/less per side? That would mean the axle would have to become UN-perpendicular to the forks, which it's not allowed to do (because of the way its mounted)?
BUt, to your credit, no, I haven't checked suspension settings. It's one of my goals this summer. The bike rides great, but I may just be used to it.
Well, that sounds about right, It was just a thought. Im not a suspension expert. But if either your rebound or pre load was set up different from one side to the other it may cause the front tire to rail harder and be more aggressive turning one direction over the other due to the different settings.
The bike may feel fine, but there may be extra weight distrubution to one side of the bike versus the other to compensate for the different pre-load, rebound and compression setting. May be minor enough that its not noticable when riding the bike, but over the course of 2000 miles little by little it may result in causing some extra wear on one side of the tire.
Well, as i stated before, im not a expert by any means. Just had a idea in my head and thought id share it with you Skanky.
Good luck with your tire though, id be interested to find out the problem if you do end up finding it.
