What is involved in removing exup motor cables on a 2015
1 reading
7.9K views 6 replies 5 participants last post by  60thannR1
Just installed Graves cat eliminator exhaust and want to remove the exup motor and cables, I know it is in the tail section, but have not traced the cables or anything.
Can anyone who has done it, share what was done to remove? Have searched and checked online, haven't found anything for the 15.
Thanks for any help
Take rear seat off. Unbolt bracket for servo motor. Unbolt cover for servo motor. Unhook cables from servo motor. Unhook cables from valve on the cat. Pull cables out from under the tail. FYI put the cover back on the servo motor and reinstall the bracket. If you keep the servo motor plugged in and mounted you will not get a code light on the dash.
If you go to two brothers sr1 exhaust on revzilla website you can look at their install instructions. it shows you how to do it with pictures. Super easy.
Better yet, get your ECU flashed and have them block the error code altogether. Then you can take off the servo and bracket. :yesnod
Thanks Guys!!
Thanks, I have a tune, I just wanted to take everything out, not difficult, all done and flashed, no codes
