What is the torque specs on the rear axle nut ??
27K views 5 replies 6 participants last post by  yankin&bankin
I tried searching and found nothing. I changed my tire and i want to torrque my main rear axle nut and dont have the torque specs.
If someone got something it would help a lot !
Thanks !
I would be cautious of the listed 108 Ft. pounds listed in the Yamaha R1 repair manual. I torqued my rear axle to that spec. and was unable to remove the rear wheel. The axle just spun against the stop (on the sprocket side) until it was distroyed. I eneded up have to grind off that side of the axle so I could drive it through the wheel. I had to replace the axle,stop,washer and nut. Take the torque values with a grain of salt. Yamaha's repair manual calls for 72 ft. pounds on the six rear sprocket bolts (which are 10mm bolts). They call out 61 ft. pounds on the counter shaft sprocket. Seems that there are some inconsistancies.
Scott
