What oil and oil filter do you use?
8.5K views 15 replies 16 participants last post by  eros
what kind of oil and oil filter are we using? i use a fram filter and mx4t mobile 1 super syn is this ok?oil changed every 1500 miles always clean..
Changing your oil every 1500 miles is fine, although a waste of money. If your using a quality synthetic the 4k recommended is just fine (unless your tracking the bike, thats another story).
And dump the fram. He's right they're el cheapo garbage.
Haven't changed my oil in the R1 yet, but it'll be Amsoil 10w-40 or the mobil mx4t, and likely a K&N filter.
Really any decent synthetic (or dino) oil made for bikes is just fine, as are most filters. The key is just making sure you have enough oil in it and it and the filter are changed when they're supposed to be.
Castrol R4 and Scotts Filter
Wal-Mart special for $2 for me...:finger
YAMAHA OIL FILTERS
These Oil Filters
have 20 x 1.5mm threads,
14 psi by-pass valve,
anti-drain back valve,
2.3" O.D. gasket
2.5" to 3.5" long.
If you have the room, I recommend the longer filters.
Motorcycle Filters.
None are recommended.
• AC Delco PF2135
• AMSOil SMF103
• Carquest 85358
• FRAM PH6017A
• Honda 15410-MCJ-000
• K&N KN-204, about $13. Metric nut on end for easy removal.
• NAPA Gold 1358
• Purolator ML16817. Imported, not made by Purolator.
• STP SMO 17
• WIX 51358
Recommended filters.
All have superior
filtering.
About 2.5 inches long.
• Purolator Pure One PL14612, about $6.
• Mobil M1-108, about $12.
Made by Champion.
• Bosch 3300, about $6.
Made by Champion.
About 3.25 inches long.
• Purolator Pure One PL14610, about $6.
• Mobil 1 M1-110, about $10.
Made by Champion.
• Bosch 3323, about $6.
Made By Champion.
• WalMart SuperTech ST7317,
about $2. Made by Champion.
Automobile Filters,
about 2.5 inches long.
• AC Delco PF1237
• Baldwin B1400
• Firestone TF2876
• Hastings LF113
• NAPA Gold 1365
• Purolator L14612
• STP S-02876
• WalMart SuperTech ST6607
• WIX 51365
Automobile Filters,
about 3.25 inches long.
• AC Delco PF-2057
• Auto Pro 2356
• Autopride CF240AP
• Baldwin B1402
• Carquest 85356
• Carquest Red B4620
• Casite CF240
• Castrol 7317
• Champion Labs Ph2867
• Defense Filters Dl7317
• Deutsch D-370
• Federated Filters LF240F
Automobile Filters,
• Fram Double Guard DG7317
• Fram PH7317
• Fram Tough Guard TG7317
• Fram Xtra Guard XG7317
• Group 7 V4610
• Group 7 V4620
• Hastings LF240
• Mighty M4612
• Motorcraft Long Life FL-821
• Napa FIL1356
• Napa Gold 1356
• Parts Plus PH2867
• Pennzoil PZ-109
• Penske 7317
• Powerflo SL14610
• Powerflo SL14620
• Pro Gauge PGO-4620
• Pro Tec 164
• Promotive PH4610
• Pronto PO3593A
• Purolator L14610
• Service Champ OF-4622
• Shell SH48
• Shell SH529
• Stp S-02867.
• Valvoline VO50
• Warner PH2867
• Wix 51356
#11 ·
castrol 20w50 and OEM yamaha filter.
had guy in town with KN filter that spun3 rod bearing due to pressure spring in oil filter breaking and blocking oil flow. K&N sent him a check for 10k and told him to keep his bike(had turbo on it) after about 4 months of fighting with them. prolly a freak deal, but ill stick to yamaha filters or scott.
Motul full syn, and K&N filters!
