So ive had both my bikes on the same dyno recently... Here's a comparison.
04 R1
K&N Air Filter
48 tooth rear sprocket (stock front)
AIS blocked off.
Stock Y pipe but the CAT is removed from it.
Slip-on Mufflers
And adjustment of Co settings through Diag mode..
No power commanders or flash..
15 R1M.
Stock as it came from factory..
The 04 does have a harder tire but.. Mich PP3..
Interested to hear peoples opinions and thoughts over the differences...
I can honestly say that i ride the M more aggressively then the 04 but thats because the electronics allow me to, as well the M feels like its got more then the 04 everywhere but the the results say otherwise..
EDIT:
The figures are true Rear wheel HP... Not calculated or Crank Calculated
TC was off... But i do believe Lift and Slide were still on..
I can't find my Dyno run with the AFR on it... Its not a pretty picture.
Looking back on FB this is what i wrote straight after doing it..
The AFR started at 17 at idle. Then operator does his thing and tries to start the run when AFR is near the 13.1 mark. It immediately goes lean (around 16-17) till about 7,500 RPM after that it sits between 14-15 then around 12,500rpm it starts to run rich dropping from 14 right down to 12.5 till rev limiter.
When he just did a run through the gears accelerating (as if on road) at 60, 80 and 100kmh AFR was a lot better sitting at around 13.5-14.5. Then when at those speeds backing off it would run richer, accelerating it would lean out.
Dyno operator actually said he could feel it wasn't giving its all, said TPS wasn't true and that as he put more throttle on he could feel the bike pulling it back. He seemed to think that the AFR sensor is out of callibration... In fact he felt certain..
It also had a RS10R on it at low PSI...34..
Here are videos of the two power runs.
https://www.facebook.com/25694430433...4987520528566/
04 R1
K&N Air Filter
AIS blocked off.
Slip-on Mufflers
15 R1M.
EDIT:
