09-14 R1 Installing Cam Chain Tensioner?
1 reading
7.7K views 28 replies 8 participants last post by  Aikuken
I am about to replace tensioner in my bike. I have locked the new one but have a question about unlocking it. When I install the new one, I need to turn counterclockwise. Is there a chance the cam chain can jump a tooth if I don't secure the chain bottom and top with zip ties?
Jumpin on the gravy train, sorry to hijack but question related and don't wan to create a new thread...yet. I checked thru forum but nothing jumped out.
Is there a recommended maintenance interval (time/mileage) for the manual cct? I purchased an 09' last year with a manual cct. For piece of mind, I want to check for any slack. Seems like a pretty straight forward check/adjustment.
You would check the slack the same way you do when installing it the first time.
Grab the directions for the Graves version. It has a good explanation.
  • Like
Reactions: Numbers and CBat
Not sure. I haven't adjusted mine in like 7 ish years.
And a new gaskets for the cover.
  • Like
Reactions: CBat
it’s always a risk when removing the tensioner that there will be a load from the valve springs on the chain causing it to release tension and jump teeth.
Thanks, bud. What's recommended interval (if you know off head)? Once a year?
depends how many miles you put on, I do mine every 2-3 months for peace of mind, literally takes 30 seconds to do, I loosen lock nut, start the bike and have it running, tighten the adjuster by HAND until it stops, and than back a 1/4 or 1/2 turn depending which mcct you have, even when installing new ones, I turn the engine over with hand pressure on the adjuster to always make sure it’s all seated correctly.
Every time I open the engine up, there’s never any excess wear on the guide/slider and timing is always within spec and not stretched
#11 ·
So that is not how the Graves install manual specs the adjustment....
And when you pull the oem tensioner you are supposed to wedge the adjustable guide to keep tension on the chain. Then after you set the tension, you spin the engine by hand to make sure it is still in time.
#19 ·
For me, personally, I guess it comes down to not trusting the previous owner's install. When it comes to vehicles, I don't trust anyone's work but my own...unfortunately is what it is.. For piece of mind, I will check regardless. If it fails, I'm to blame. Once I check (and adjust if necessary), I will forget for years to come.
Peace of mind/cheap insurance that it’s not excessively stretching from Other points of failure as well. I put on a lot of mileage, I don’t think anyone would recommend going to oem Style especially after all the issues yamaha has had with them, with multiple points of possible failure. But we all know that, Sometimes hearing a clacking is too late to find out there was a problem in the timing drive. I’ve seen sliders shredded and cracked from plasticizing, as well as dowel pins wallowed out and demolded plastic to metal
bond. (I used to work on a lot of triumphs) 😂 It’s not marked on my calandar to “adjust chain tension” but it costs nothing to do.
#22 ·
Just FYI (for the whole world reading these post) adjusting a manual CCT on a 09-14 R1 every 2-3 months isn’t remotely necessary.
100% agree; however, I'm glad I checked the previous owner's install. On tdc, I hand-tightened at least another full turn. Does that mean anything wrt to longevity cam chain/drivetrain? I have no idea...but I know I won't check or adjust again for as long as I own this bike unless it starts to sound like a bag of bolts, full stop.
Another FYI:
The only times I would check manual CCT tension is after a short bit of miles after initial install and during valve adjustment (do valve adjustments sooner than the recommended interval if you romp on it often like somebody with a race license or constant track day rider).
I had been meaning to do my valves this winter..... but I got distracted building built in bookcases this winter. Next year I guess.
#29 ·
If you set your crank to tdc, and you don't remove the camshaft cover on top of the engine, you don't need the zipties, as the cover has a little piece on it that limits the movement of your chain away the camshaft gears so it won't skip.
If your engine is our of your bike and the top cover is open, apply zip ties.
