Has anyone received an ABS delete plug from FTECU that works on the 2020+ R1 or R1M? Mine arrived dead out of the packaging, the speed sensors were faulting out immediately before I left the garage. Rode a few miles to see if the sensors would clear up. Got back to the house pulled the code(P0500.) Decided to swap the pump back in since this was the only new mod and could account for my other 2 CELs (exhaust servo and AIS solenoid.) Everything works perfectly again. It appears the plugs are causing wheel speed sensor P0500 fault. This makes your speedometer read 0, quickshifter is locked out, SCS is disabled, and various dash lights. Plugged the ABS delete back in to verify what I was seeing. Back to immediately faulting out the speed sensors. Yes my battery was out of the bike when this was installed and uninstalled.
Update:
Got a refund from the manufacturer.
Update:
