So how many potential problems am I missing from my list of things that are known issues with the '09-'11's?
1. CCT... Can and should be fixed easy by dealer under warrenty. On 2010+ models, some say it was upgraded, some say no.
2. Death ray headlight lens'. some say Yamaha swapped out the lens' on the '10 models with frosted bottoms, some '10 owners say theirs didn't have frosted lens' and had to use the decals. Funniest issue I've ever heard of personally.
3. Noisy grabby clutch that Graves has a fix for. Some say the clutch is junk and some say there is nothing wrong with it and you just need to adjust the clutch lever. What's the deal with soaking the clutch plates in oil for 2 days? sounds like something a Duc would require every 7,500 miles. Is that a band aid fix the dealer does a couple times or so, to get you out of their hair until the warranty expires?
Not sure it it was the '09-'11 R1's or the '07 and '08's that had some sort of starter motor thing where something could break off in the starter motor and seize up the starter motor.
Of these, number 3 is the only one that concerns me the most.
