2011 R1 - What It Needs to be Competitive.
48K views 307 replies 94 participants last post by  Predator04
OK, so this place has gotten a little boring lately, with not nearly enough of the discussions on motorcycle technology that I love to read and participate in.
There's at least one other thread about the 2011 R1...and it's pretty worthless, with most members chiming in with the usual, brilliant comments, such as "it will have 2 wheels" and "Yamaha will sell one in blue."
In this thread, let's skip the usual, jaded drivel, and have some actual, realistic speculation on some of the changes and features that should be included on the new R1 for 2011.
As sick as I am of hearing about the new BMW S1000RR, it absolutely must be included in any discussion of new 2011 models from the Big 3 Japanese OEMs.
This new Beemer has absolutely blazed a new trail in several facets of Superbike performance - most notably in power, as it absolutely annihilates everything else in the dyno room...at least in top-end power (I'm sure the R1 beats it in low-end, and there's no question that the CBR hammers it in the midrange, and up to around 11K RPM).
And then there are the electronics. While the BMW wasn't the first sportbike to offer traction control (the 1198S comes to mind), it has so far been the first to offer it at a relatively affordable price point.
I have also heard rave reviews of the S1000's handling. A friend of mine who owns one, and who happens to be a member of this Forum, has compared the handling of the bike to the current-model R6. On our recent trip to the Smoky Mountains, he remarked that he much prefers the handling of the Beemer to his previous street bike, a 2007 GSX-R1000 - a bike widely acknowledged to be one of the best-handling machines in its class.
So, how will the Japanese factories, specifically Yamaha, answer the new BMW?
I think most of you would agree with me that the current R1 is a bit long in the tooth when you place it side by side with the (arguably) 2 class leaders, the Honda (oil burning issues aside) and the new BMW. The R1 is a very impressive and unique machine, and has, in my opinion, the best throttle response, and connection between the rider's right wrist and rear tire, of any of the current literbikes, and possibly of any production motorcycle ever built. But it also lags behind the competition in several key areas:
- Power: It's down at least 10 HP (top-end) on practically every other literbike
- Weight: While it can be tough to pin down the actual dry and wet weights of a motorcycle if you don't have a scale at your disposal, it's common knowledge that the '10 R1 is in the neighborhood of 480-485 lbs. fully-fueled and ready to ride. That's quite a bit heavier than my '07 model, which is around 460 lbs in stock configuration, and way heavier than the lightweight of the class, the Honda. (Incidentally, the '09 GSX-R can be brought down to pretty close to the Honda with the installation of an aftermarket exhaust.) Yamaha need to put the 2011 R1 on a serious diet. To be competitive, the R1 needs to be brought back down to the weight of the 07-08 model, at the very most. This would be a loss of at least 20 lbs, but that's what the new R1 is going to need in order to get competitive again.
- Handling: This might be a sub-category of weight, but when I rode the 2009 R1 on Deal's Gap last summer, I noticed that the steering was quite heavy in comparison to my '07. No doubt, part of this can be blamed on OEM Dunlop tires that had already been used and abused by our own Slomack, plus the fact that I did not have the opportunity to tune the suspension ride height or damping to my preferences. While initial turn-in was average, the motorcycle required a lot of effort at the inside bar to steer it down into a turn, and then required an inordinate amount of pressure at the inside bar to hold it at a static lean angle. All of this cannot be attributed to worn tires or suspension set-up. The bike just needs to be made more nimble. And there is no question that the bike is heavy when you sit it next to a current-gen Honda CBR1000RR or Ducati 1198. So, Yamaha possibly needs to address suspension geometry to quicken steering.
- Electronics: In order to get back to the top of its class, the 2011 R1 is going to need to come with Traction Control and ABS as standard equipment. With the traction advantage already provided by the uneven firing order, it would seem that adding a traction control system would be the next logical step...and with the sophistication of the current ECU, I would think that TC could be incorporated without too much trouble. The YCCT ride-by-wire system should also ease the incorporation of TC. It seems that everything is already in place for the inclusion of a TC system. As far as ABS, we are already more than 10 years into the 21st Century. Every new sportbike should have ABS on the option list.
So, in summary, these are the changes Yamaha needs to make to the 2011 R1 in order to put it back where it belongs...at the top of its class:
- At least 20 more HP. This is a conservative suggestion. Most dynos are placing the 09-10 R1 at around 145 RWHP, so a bump of 20 HP would still place it significantly below the class leader (the Beemer). However, together with a weight reduction, and other improvements, I believe it would make the R1 competitive again.
How could it be achieved? The obvious answer would be a substantial bump in compression ratio. At 12.7:1, the current R1 is "in the middle" when compared with the other literbikes. Modern construction and materials would easily support a fairly big bump in CR...say, to 13.1:1. This would also improve low-end and midrange. The second obvious answer would be more Revs. Again, modern technology would allow for a bump in RPM, as demonstrated by the BMW. Obviously, Yamaha would have to do some major lightening of engine internals to support this, especially with the uneven firing order.
- Minimum 20-lb. weight reduction. Not much to explain here...they just need to do it. Other OEMs (ahem, Honda) have proven it's possible.
- TC & ABS. Several companies are now offering TC & ABS as optional equipment...but it's my feeling that Yamaha should be the first to include these technologies as standard equipment, included in the sticker price. Granted, this sticker would be higher, but people would be willing to pay for it. I also think that Yamaha could get ahead by developing a proprietary version of traction control, whose function could be integrated with and complemented by the already brilliant function of the YCCT and uneven firing order of the crossplane crankshaft. The current-gen R1 already has the best throttle response in the business, and the addition of a good traction control system would make it a world-beater.
If Yamaha were to add the above features, and make the changes I suggest here, while keeping the price increase to an acceptable level, I believe it would put the R1 well on its way to being the dominant Superbike again.
Regardless, it will be very interesting to see, over the next few years, how the Japanese will answer the advances and gains in market shares now being achieved by the Euro OEMs.
I welcome the thoughts of R1-Forum members on this subject. Let's try to keep this a civil, informative, technical discussion.
In this country, in my opinion, the price is already well beyond an "acceptable level".
All they need to do is lose some weight and include an un-neutered ECU. Have you ridden one with the ECU reflash?
I'm not big on rider aids. TC is a gimmick for street. More than half of the guys here with the new model don't even ride in A-mode. Why do they need TC? To find limits they'll never explore? On the other hand, ABS would be useful to all the noobs and squids.
#42 ·
yup TC is a gimmick. Completely agree. But my bike is in A-mode from the second its started up until it pulls back into my garage and is shut off. haha. Standard mode bores me now
#11 ·
So are we talking a bike built for the Street, or a platform for a "Superbike" race bike ?
I bought the R1 because I thought it'd be the best "Street" bike of the affordable litre bikes.
I've only had my '09 R1 for a few weeks, and while it's no lighter than the bike I came off, Triumph Speed Triple, and the steering is heavier, it's gawd awfull fast enough, and I ride with a 180hp gixxer and a new Beemer. What's that 10 extra HP worth on the street ?
I'd be a fan of 20lb lighter for sure, but with the counter balancer, they're gonna have to spend some $$ on un-obtainium parts for sure.
Truthfully I do like the look of the older R1's better, not sure which year, but I do feel it's got a bit of a "Tubby" look.
I personally wouldn't want traction control or ABS, so I'm glad I've got this one and not the next.
Price, probably the best way to garner mkt share in this economy would be, to be, the Price Leader. Shave some weight, and some $$$ and make it a bit sleeker, & I think it'd be successful.
(and it'd be really nice if the new sleeker plastic would bolt right up to my '09)
I have an 09 with stock settings and tires, after I got my suspension setup and some new tires it handled 10 times better. Not sure how it compares to other literbikes but I'm happy with my 09. Like some have stated, do you really need 200 BWHP for the streets? You're not going to be riding 150 MPH+++ that often (if at all) on the streets. I wouldn't mind the bike being lighter and having ABS though, I don't think you need TC with the crossplane.
Yawn.
Sorry, not trying to be a jerk, but your arguments are old and tired.
We don't need TC with the crossplane?
Well, let's see: Do we really NEED radial brakes w/ radial master cylinders for the street?
How about inverted forks?
What about monoshock rear suspension?
While I'm on a roll, how about radial tires? Wouldn't bias-ply tires be just fine for the street?
What about water-cooling? Isn't air-cooling suitable for street riding?
#19 ·
ill bite
To be competitive in the market the 2011 R1 must...
lose weight significantly,
ABS
Price is always a factor. But then again...a 1198s costs how much and still sells today.
TC could be optional. ABS wouldnt be bad as it has real world benefits on the streets.
The engine is fine at EU standards so a de-restricted bike will be on par with all else.
The main issue with the bike is not power or lack of TC or looks or whatnot. It is weight. Cure the extra weight and even shed a few more pounds and that will make the bike better in every category, itll even take care of a lower power figure.
#23 ·
Yeah, I think list price on an 1198S is around $22,000.00.
Is the 1198S a lust-worthy bike? We know the answer to that question...in fact, that's what would be sitting in my garage if I had that kind of disposable $$$...and if I didn't like to crash so much.
But yeah, I don't think we have to worry about the R1 getting up into that territory.
my 2c : i love the yama and im still about 3000euro away ..sold my 05 zx6r for 6000e.. i would like the yama to go on a diet but to retain the look n style it has now(apart from the stock exh).. hopefully i will get the permission to ride it for work as i did the little ninja. my partner and i ride our bikes on work about 5months per year. he just bout the 08 raven and is so so so much supreme in every way to my old bike..but when i tried the new yama i wanted to steal her:)
pozz zgb! jedan iz interventne;)
#22 ·
Do you ride with someone on a regular basis who has a new BMW?
I do, and he freely admits he can't use all the power...(it's not like I can either at this point). It'll be interesting to see how things go as we both get more comfortable on our bikes, we're pretty evenly matched... or were before the changes.
To the OP
Great write up even though i would argue many points your stating.
I do think the big FOUR (you have to include kawa, even if your not fond of the brand) will be replying good and solid.
If you look at the Super Tenere it comes with ABS and TC. The problem here is everyone wants less weight but to include some heavy arse ABS system. Yama probs has already developed a very light system but it may cost the end user.
You cant argue on HP since its restricted in the states to 145RWHP, so i dont think you should be stressing on the amout of 20hp.
Sorry i forgot to mention increasing revs and compression ratio also shortens the life span of the engine doesnt it?
Pricing, well i dont think ive actually read on this forum how BMW is capable of keeping the pricing so low, its because they'll be producing different models every four years. So the next update (edition) is 2013.....
Longer intervals results in lower cost of producation.
Would you guys like that?
I think there are afew more bits to be added to the dream spec 2011.
The Japenese have to seriously work on updating other parts aswell which werent mentioned.
Showa on one hand should produce replica Ohlins like Sachs is doing.
Wheels should come in a different style (about time?) and perhaps with afew pounds off if possible.
Braided hoses would be a nice bonus?
Perhaps better quality brakes to match brembos two piece caliper on the Beema??
#29 · (Edited)
To the OP
The Japanese have to seriously work on updating other parts aswell which werent mentioned.
I'm really not brand-loyal...I'll buy the motorcycle that I like the best and that fits me the best. I was just stating that Kawasaki has been the cheapest Japanese OEM in terms of sticker price (their fit & finish and build quality has also been, arguably, the poorest of the Big 4, as well). Kawasaki has also historically, more often than not, had the fastest, most powerful bikes in their respective classes. So, that does represent a good bargain (for a poor, fat guy, at least:lol:p)!
You're right about the Super Tenere...quite comical how Yamaha tries to present it as being truly off-road capable...at a weight of over 500 lbs.!
Even with aftermarket mufflers, the '10 R1 only gains 5-7 HP, so it's still pathetic in the HP department when compared to even the Japanese competition, let alone the BMW!
As for the effect of increasing the tune of the motor on longevity, the guys at BMW don't seem to be too worried about it, do they? Of course, only time will tell.
#30 ·
You can argue all day about being able to use the availiable HP on a liter bike or not, but the fact is, "Horsepower sells liter bikes". Yamaha needs to be on par with the others, or the bikes will get killed in the magazine shootouts, and sit on the showroom floors.
Yes, I know a lot of people here will say they did not buy their R1 for the HP, but a lot of people do make HP their top priority when buying a Superbike. Personally I love my 07, but when I buy my next bike, if things stay the same, it probably won't be a Yamaha.
#38 ·
the 09/10 R1 long in the tooth? sh!t it just came out last year, won the world sbk title in its 1st year, has been doing a good job for the most part in world sbk this year & has been winning races in ama sbk. its a street going race bike that has been winning races & has a world championship to its credit, you cant ask for more than that. it sounds like your into the whole who has the biggest Hp argument or my bikes faster than your bike:flex:. also sounds like your buddy on the bmw has brain washed you, sure he is going to brag up the new bmw beings he just got it. ride your own bike and enjoy it
#41 ·
I do agree the jap bikes need to make a significant comeback to keep on par. But I dont think TC and ABS are completely necesary on a bike. Nor even on a car. Thats always the first thing I do in my car...turn off the TCS unless its raining. (well unless I want to purposefully slide the mustang around) Plus where would they shave the weight off? The exhaust isnt their fault. thats emissions. If they do shave off 20lbs...most of it will just be put right back on if TC and ABS were included.
Right now the R1 IMO and many others opinions puts the power to the rear much better then the other bikes..very linear and smooth. So i dont think a massive jump in HP is needed. Maybe get it to a steady 160 average on dynos and it can be a good competitor. Or just get rid of the 80% limit in revs on top gears. find a way to increase the mid range and It would be golden.
But I dont think Yamaha or any other manufacturer is going to do anything major this year. They will release the same bikes they have...with maybe a slight tweak here and there. And bide their time for the time being and work on a new design of the crossplane for the 2012 model. No one wants a rushed model with 20hp more released just because BMW did it....ok...we do...but realistically that would be a horrible move to make. With a bump in power like that many things need to be watched over taken into account and tested over and over again
So IMHO I dont think any bikes will see any major revisions this year. Give it till 2012. Then the competition will truely being
#44 ·
As for TC/ABS not being necessary...maybe not...but refer to my earlier post:
http://www.r1-forum.com/forums/showpost.php?p=4448630&postcount=16
As for the power increase...that's approximately what I called for. But, as I said, that's conservative...it really needs to at least MATCH the output of the BMW IF we want the R1 to be back on top.
Don't you think Yamaha would like for their literbike to be #1?
I'd also have to disagree with the argument about this being a bad time to introduce new technology and jump ahead. What if the bean counters over at BMW had vetoed the engineers' proposal for the S1000 because of the economy? Then, BMW would still be building only stodgy, utilitarian workhorses...the Subarus of motorcycling!
So, I strongly disagree with your assertion that Yamaha should not take try to turn lemons into lemonade and use the economic downturn to jump ahead of the other Japanese OEMs, and catch up with BMW.
#47 ·
yankin&bankin;4448693 Put them at any track or mountain road with any kind of straightaway said:
KILL[/B] the R1.
You are correct here however Rossi has proven time again that top speed is not mandatory to win/be in front....im not comparing the m1 to the r1 but it is racing...
maybe some naked squid with a 12 foot swingarm on a r1 with twin turbo supercharged turbine hybrid engine and a big bottle of nos will take out the Beema in style, would you then want a bike like that?
#48 ·
well lets take into account that Yamaha are not retards. They have figured it out before to be the top bike and they will do it again. I guarantee they bought 500 beemers and are thrashing them, tearing them apart, figuring out why they weigh less....etc. my bet is the 11 and 12 will have it figured out better then last year.
Lets remember when everyone cried about the R1s low end... well they changed things up to help that. When you take some here, you give some there. eventually they wil tune it to perfection.
Technology is technology. If we have the means to put it on, it will be there. ABS has saved tons of lives and while some of you cocky people think you dont need it, i might agree. With the new guys...and we have all been there... ever lock up your rear tire on accident? I did. You can bet that will all be option
sorry if im a bit behind the recent topic.... just puttin in my two cents
#50 ·
To be more competitive? hmmmm.......
Back to your original question, The 09 R1 could be considered a success or a failure. The economy will have to be factored in. Did Yamaha reach its sales goal? I think more R1's were sold than almost any other Jap manufacturer's liter bikes except maybe Honda who gave away their 08's maybe due to oil burning issues,They almost bet the company that the Crossplane would carry sales NOT horsepower.They built a great machine but BMW built a better one in almost every way possible. "MotoGP" technology was their hook. Im sure that quote sold a lot of R1's. it's gonna come down to individual taste and riding style. I almost didnt buy the 09 because it came in last place in one shootout.But the styling and the crossplane sucked me in.I love the bike as it gets better and better as I pile on the miles.Can you imagine if the R1 had better brakes, 20 more hp and 20lbs less weight?
#51 ·
Competitive with what? bench racers? geeks? squids? parts monkeys?
Or the elephant in the room--the bimmer?
The truth is, we're all terribly spoiled by the bikes, (it's amazing they're still road legal!!!) and we should all spend more energy on something within our control--like seat time.
Break up the sewing circle and go ride.
P.S. The OP argues just to do it, especially when he's dead wrong.
#53 ·
wheres the oil guys too? I'm sure we can get something started if we say the BMW comes loaded up with Amsol oil and the yamaha gets Rotella. Thats why the yamaha is falling behind. :hammer::hammer:
