Status
Not open for further replies.
2016 R1S Quickshifter Help
23K views 14 replies 10 participants last post by  2018R1JTSDVK
2016 yamaha r1s quick shifter help
So I noticed that the yamaha r1s doesn't have quick shifter however in yrc settings I see where I can turn on qss but does nothing and I've been on ebay and saw the shift lever for 200usd so Imuch wondering if I can buy that lever and install to my bike and try to use the stock ecu to manipulate it with the qss system or do I need a module as well for it to work like bazzaz or flash tune etc
Yes you can use the factory quickshifter that was included on the R1/R1M. This is a good video that shows the location where you plug it in, as well as in the video and the comments he tells you how to enable it in the settings:
If you're looking for one, I have an OEM unit that I took off my R1 @ 100 miles. Replaced it with an FTECU autoblipper. PM me with an offer if you'd like it :)
Plug into white connector above shifter within the rubber boot.
Put the bike in 2nd with the bike off, press and hold the shifter up and turn the bike ignition on.. hold the shifter up for 10 seconds and it'll enable.
Save
yea if you follow the wires from the oil pressure switch and the kick stand switch they go up into a rubber boot that also has the quick shifter plug. the r1s will have a white cap you remove to plug in the sensor. yamahasportsplaza has the units for 138 dollars and 16 for the shift rod cheapest i have seen
Save
Having the same issue 2018 R1, the QSS setting instantly goes to off when trying to select it. Everything else on the bike works. Any suggestions ? I’ve tried the 2nd gear, bike off, push up on the shift lever, bike on, wait 10 seconds and try to enable. No dice.
Also have an FTECU quickshifter, does the same thing. All 3 QS wires check good from the QS to the ECU. Kind of at a loss here. Looking for any help.
Status
