So I just installed a fender eliminator in my 99 R1 and I need some help to get the light working properly. Here is the break down:
FENDER ELIMINATOR LED WIRES:
x2 Red Wires: L+R Brake Light
x2 White Wires: L+R Parking Light
x2 Green Wires: L+R turn Signal
x2 Black wires: L+R ground
BIKE WIRING HARNESS:
Yellow wire: brake light
Blue wire: Turn Signal (can't remember which side, easy to figure out with tester)
Green Wire: Turn Signal (can't remember which side, easy to figure out with tester)
Brown Wire: Voltage goes on/off when turn signal is on. Must be the "flasher wire"
Black with stripe: Parking light?
Black with stripe: parking light?
Black Wire : Ground
So how do I connect all this?
Black Wire : Ground
